| Hello, I have two transformers. One is 220:1 from a camera flash circuit and another completely different transformer is 10:1. If I wire the primaries in series and the secondaries in parallel...will the total ratio be 230:1? would really appreciate some help. thanks, George L. | |
| The short answer is no. Why do you want to do this? If the purpose is to get more voltage out of the secondary, is the difference between 1:220 and 1:230 worth the trouble? Why not just boost the primary voltage?
| I guess if your voltage was close to the breakdown voltage on the primary it would help. This question's a real noodle-scratcher though, what would the ratio become? | |
| Hey, the reason i am asking is because I have the stun gun project on my breadboard. It can produce 400V at 7mA max. This is using the 220:1 transformer. I need a higher Voltage out. I thought I could put a different 10:1 transformer is series/parallel as described in my first post and get 4000V. I guess you can't do this, right? thanks, George L. | |
What you can do is feed the secondary of transformer A to the primary of transformer B. This gives you an approximate output of the ratio of A x B at the secondary of B. However, the primary of B MUST be able to withstand the higher input voltage and the secondary of B the much higher output voltage. If transformer B is totally encapsulated in epoxy or such you might have a chance but do exercise extreme caution. Klaus | ||
