You need to first get the digital data from the audio file - it's not stored there as digital data, but as audio tones - for a start you need to convert that back to the data. Presumably using a modem of some type!. Assuming you have access to the original machine?, you should be able to read the data after demodulation in that!. | ||
| ignoring? Im trying to get help here and your not helping me. I dont have the machine or else I wouldnt have posted silly. Now... The data is NOT an audio, it is a square wave digital bit stream that has been recorded onto a tape. its wave form has been degraded over time as well as this was pulled off of a tape itself.... Now I ask this... If this were CMI incoded, and indeed there was 6 1's representing the start bit, how could you have 100 bits of valid data after the start bit without worrying about a consecutive 6 data bits triggering a false start bit? Any theories... | |
As you don't have the machine, presumably you are trying to reverse engineer the data?. | ||
| Ok, now we're gettin somewhere Well.. Yes reverse engineering this,, decoding what ever you want to call it... I can see on a time line here that the 6 bit start section that is so prominent are 30mS apart... Thus means this common pulse is sent about 35 times a second which is about what the frame rate is of the amimatronic. And taking these FACTS -> 100 data bits sent every 35-40 times a second.. I don't see how it could send that much data that fast if this were sent as an audio file like you propose. I mean,, if your telling me that it's impossible to record a digital bit stream onto a tape then please say so cause we can eliminate this idea, but I just really feel to get that much data out so fast here this must be the case?? btw,, I've noted that the 2 frequencies here are tone1=2khz and tone2=4.366khz | |
| | (permalink) | ||
What degree of movement, and how many different items, are you talking about?. | |||
| There are 100 seperate movements, on/off movements that are refreshed approx 35 times a second with this data signal. | |
