| I'd like to run a 4 ohm load using 2 lm386 chips in parallel. Would I just do it like normal and then split the input to go to both chips, then hook both positives together on the output to go to the speaker?
__________________ Life is what you make it. | |
| You can't connect the outputs of amps together and expect them to drive a load equally. One will have a slightly higher gain than the other and it will hog the load until it fails. Equalize the gain of two amps by adding a resistor in series with the outputs. Maybe 0.22 to 0.33 ohms from the output of each amp to the load is suitable.
| Hmm. When paralleling lm3886s, which are way larger, 50w a piece, you use 0.1 ohm resistors. Here is a schematic for them: http://chipamp.com/lm4780.pdf Well, thats actually a 4780, but a 4780 is two 3886s in one chip. Do I need the part with the 2.7 ohm resistors/cap to ground?
| | (permalink) | ||
The min and max gain of an LM386 is made internally and isn't spec'd. Since the power from two LM386 amps is so low, 1/4W 0.33 ohm resistors are fine. Quote:
__________________ Uncle $crooge | |||
| Ok, so higher powered paralleling requires smaller ohm resistors then?
The lower power amps have their gain built-in but don't have a min and max gain spec'd, so higher valued resistors should be used to equalize their different gains.
| Ah, ok. I get it now.
