Old 23rd February 2006, 10:35 PM   (permalink)
Default MultiSIM 74LS107
I'm currently designing a Shift register in MultiSIM; using two 74LS107's, and a 555 timer.
My problem is that the Pin 14 doesn't exist on the component it defined with Power 1 as VCC, but I need to connect it somewhere else....
I am using MultiSIM Version 8.3.3.0
Can anyone please look at my MultiSIM design (Attachment below), and see if you can see any problems? I know it's kinda messy with the auto routing wires.
Note I had to use 1N4001GP instead of 1N4001 (Can't find equiv)
And I used 100nF cap instead of 0.1 uF for C2
Also had to use 1N4735A instead of 1N4735 for D1
I'm only measuring like 107 pV for the LED's!
windozeuser is offline
Old 24th February 2006, 12:20 AM   (permalink)
Russlk is offline
Old 24th February 2006, 12:22 AM   (permalink)
It's actually a multisim file so somebody can load it up with multisim...
But I'll make a JPG real quick also.
Photo of circuit is below:
Old 24th February 2006, 01:43 AM   (permalink)
Even tho the 74LS doesn't have power pins, you have to tell it that it is connected to 5 volts. You don't have a 5 volt supply; it won't run on 9 volts. You need to find out how Multi Sim gets power to the part, or else make your own symbol with power pins.
Russlk is offline
Old 24th February 2006, 02:11 AM   (permalink)
Not sure how? I read the MultiSim Documentation I didn't find anything. Can any MultiSim expert help?
UPDATE: I Noticed I didn't use pins 10 and 13 of the 74LS107D. I modified the model and changed them to ground and VCC respectively. Now The red LED's work, and the greens one's wont. Hey, atleast something works now...
Old 2nd August 2007, 06:18 AM   (permalink)
Pin 4 is Vcc and pin 11 is Gnd on a 74ls107
wcsur is offline
