Old 21st February 2006, 03:30 PM   (permalink)
Default Mods for a Dean Markley K-20X
Ok, I have a Dean Markley amp that I just love. But I want to mod it. First, a line out. This is the lineout I've come up with so far. Everything else on the schematic is original.
So far I've added two 1/4" jacks to the back of the amp. One for power from the amp, and one to go to the internal speaker. I'll be adding the lineout also.
As far as other mods, I was thinking of swapping out the 2200uF/25v power supply caps with 6800uF/25v caps. I think it would give me more punch on the low end, acting like a stiffening cap along with the filtering it would do anyway. Think that would help or should I go larger?
btw, its a 15wRMS amplifier.
Life is what you make it.
joecool85 is offline
Old 21st February 2006, 04:26 PM   (permalink)
I would suggest you don't connect the line out socket directly like that, it will load the existing signal and make it quieter. Either add a series resistor (which will make the line output signal smaller), or (preferably) add a buffer to feed the line out.
As for the power supply caps, I doubt you would hear any difference?, but it won't do any harm, and it's 'technically' an improvement!.
Nigel Goodwin is online now
Old 21st February 2006, 04:57 PM   (permalink)
How about doing it like they do in the K20B?
Old 21st February 2006, 06:47 PM   (permalink)
That's fine, it's an attenuator off the speaker output - the power amplifier acts as a buffer, and the attenuator isolates it as well.
Old 21st February 2006, 08:12 PM   (permalink)
Cool, I'll do it that way then. Would it have an adverse effect if I only used the line out and the speaker was disconnected?
Old 22nd February 2006, 09:26 AM   (permalink)
No, it would be fine - it's only valve amps that don't like O/C loads.
Old 22nd February 2006, 12:35 PM   (permalink)
Thanks, thats what I thought.
One more question. I'd like to set it up with a footswitch to switch between the clean and OD channels. Right now, as you can tell in the schematic, it uses a DPDT to switch between channels...is there a way to set it up so that when I plug in a footswitch pedal (which I would make) I can remotely change channels on it? A lot of amps have that, and its really nice.
Old 22nd February 2006, 12:38 PM   (permalink)
Replace the switch with a relay, and use the footswitch to switch the relay. Some footswitches are latching, some are momentary contact, a latching one would make it much easier!.
Old 22nd February 2006, 09:28 PM   (permalink)
Yeah, shortly after I posted that, I figured out the relay thing lol.
Will the 1k resistor to ground off the positive on the line out bother the load of the amp? I mean, its rated for 4-8 ohms, wouldn't that effectively give it a 1k load?
Old 22nd February 2006, 10:04 PM   (permalink)
Actually it will give an 11K load (as the 10K is in series with it), however this will reduce depending what you plug in to the line out - but can never drop below 10K.
It's no problem whatsoever!.
Old 22nd February 2006, 10:50 PM   (permalink)
But the TDA2030 in the amp puts out 8watts at 8 ohms and 14watts at 4ohms...wouldn't it put out next to nothing at that much resistance?
Old 23rd February 2006, 10:46 AM   (permalink)
It will put out VOLTAGE! - which is what you want for a line output signal - it's not supposed to provide power to feed a speaker!.
Old 23rd February 2006, 12:59 PM   (permalink)
But it taps the + on the speaker out...what I'm getting at is wouldn't it kill the amount of wattage going to the speaker? I know the line out doesn't need tons of power lol.
Old 23rd February 2006, 03:17 PM   (permalink)
No, it's taking no power from the speaker at all, it will take a tiny amount more from the amp - but this is far too small to make any difference.
Old 23rd February 2006, 03:22 PM   (permalink)
Good. Thanks for all the replies Nigel. It seems you are one of the only people on here that likes to respond to my questions :-)
