| Hello forum, I'm using a PIC's analog input pin with the internal AD converter to measure the voltage from a voltage devider, as in the circuit diagram below. Now, the PIC's datasheet says max 10K input impedance, but I'm not sure how to calculate this value. The resistor devider supply can vary from 4V to 10V. Thanks for any help. Regards, Futterama | |
| The source impedance should be no more than 2.5K, your divider is considerably more than that!. This will restrict how fast you can switch between channels, and may have some bearing on accuracy. If you can't use a lower value potential divider, you should consider an opamp buffer between the PIC and divider - check my analogue tutorial!. | |
| | (permalink) | ||||
Regards, Futterama | |||||
| | (permalink) | ||||||||
You only need ohms law and parallel resistors to work it out - you need to work out what value resistor you would put in parallel with the bottom resistor to give half the voltage - the extra resistor equals the source impedance. Quote:
__________________ I thought what I'd do was I'd pretend I was one of those deaf-mutes. | ||
| | (permalink) | ||
| | (permalink) | |||
| Nigel, that's odd, I used an Excel worksheet to do the calculation, and I also ended up with 7.5k with the method you mentioned. | |
