Old 29th June 2003, 05:44 AM   #1
Default 500K Or About Pot With A Rotary SPDT Switch?
I'm looking for a pot with a rotary SPDT switch that's at least 500K. I've been looking for a few weeks now and can't find one. I emailed several places, but I also get people who claim they have one and it turns out to be SPDT. I live in the USA, but if the place ships internationaly, that's good enough. Anyone know where to get one?
sjaguar13 is offline
Old 30th June 2003, 06:28 AM   #2
I can't say I ever saw a SPDT switch on the end of a pot. SPST, yes, even DPST's are around but double throw switches, why'd you want that? Usually you want a pot to switch something on or off which does not need a DT switch.
Whadda ya building?
If you have no luck you can mount a cam on the shaft and a micro switch next to it, it'll do what you want but it's a bit more complex.
Klaus
Klaus is offline
Old 30th June 2003, 05:47 PM   #3
It's to control LEDs and a 555 timer. The switch is for blinking or always on mode. The pot is to adjust blinking speed. Do I not need a double throw switch? I found one DPDT pot, but it said it was an on/on switch and I had no idea what that meant.
Old 1st July 2003, 06:07 AM   #4
I see what you are getting at but do you *really* need the pot and the switch controlled with one knob? It would be soooooooo much simpler to get just a 500k or a 1 Meg pot and a seperate switch.
If you do not have the room for that you might try junked car radio's, they have pots with concentric shafts where the switch operates independent of the pot knob setting - its like two knobe in one.
Ordinary switch pots operate the ST (single throw = 2 contacts, eg. ON/OFF) switch at the start of the pot track, hence there is no way to use a DT( double throw = changeover = 3 contacts, eg. ON1/OFF/ON2) switch since the knob turns only one way.
Klaus
Klaus is offline
