Old 6th February 2006, 04:48 PM   #1
Default Delta-Star or Star-Delta Transformation
For balanced 3-ph ac circuit analysis, a delta-connected-load can be converted to be a star-connected-load. Is the theory applied to a delta-connected-source? Can we convert a delta-connected-source to a star-connected-source in circuit analysis? Thanks.
Do we need to adjust the "phases"? What is the values of θ1, θ2, and θ3 in the equivalent star-connected configuration as shown in the figure below?
powersys is offline
Old 7th February 2006, 03:31 AM   #2
Yes, you may compute an equivalent star connected source for every delta, and an equivalent delta for every star. The voltages and phase angles get changed a bit. It's been 34 years since I did that so I don't remember the conversion factor.
Delta/star/delta conversion is at least on chapter in every motors textbook ever printed for the last 75 years.
R.G.
R.G. is offline
Old 7th February 2006, 12:58 PM   #3
Yes... We can find it almost in every textbook on electrical engineering. However, the textbooks I read so far do not mention about delta-star conversion applied on 3-ph voltage source. Therefore, I'm not sure, after the conversion, θ1 is still 0 degree, or shifted some degree... Pls advise. Thanks.
powersys is offline
Old 7th February 2006, 03:10 PM   #4
Do you mean the relative phase between the three or the absolute phase of the hypthetical coverted sources compared to the original source?
Imagine drawing the star sources into the delta arrangement in a different color, with the star point in the middle so the output leads are the same. Imagine that the V(an) leg of the star comes out on the lead that connects Vvab and Vbc, that V(bn) comes out on the lead that connects Vbc and Vca, and that V(cn) comes out on the lead that connects Vca and Vab.
Let's work backwards. Assign Van a phase of 0 degrees. That makes Vbn be +120 degrees and Vcn be -120 degrees. From there, by inspection the phase of Vab must be zero degrees minus -120degees or +120; Vbc must be 0 degrees minus 120 degrees or -120 degrees, and Vca must be 120-(-120) or zero.
You now have the differences in phase between the two. Work it forwards now.
R.G.
R.G. is offline
Old 8th February 2006, 03:33 AM   #5
I still could not visualize how to relate the phase of star circuit to that of delta circut... Would u pls advise? Thanks.
powersys is offline
Old 8th February 2006, 05:22 AM   #6
Imagine that you have only the star circuit.
The delta voltages must be simply the differences in the voltages at each output line of the star circuit. This is true for instantaneous as well as RMS voltage.
Therefore, if you assume that you know the phases of the star circuit, the phase of each leg of the delta must be the difference in phase from leg to leg of the star.
R.G.
R.G. is offline
deltastar, stardelta, transformation
