Hello,
'cause it's my first post, a big hello to everyone here! :-) I hope you won't throw me out after my first silly questions! I'm looking for a constant current source with a low voltage drop! The application: Power comes from a bike's dynamo. Voltage is AC at frequencies roughly between 30Hz and 100Hz. Voltage can vary (at max.) between 4.2V (climbing a hill) and 7.5V (normally less, but depends on dynamo and frontlight's current draw). The thing I want to power are two red LEDs in series, normally they are 2V each. They'll get between 10 and 20mA. So now I need a supply with a very low drop-out, to get a satisfactory current even at 4,2V. Also, I'd like it to be simple! The circuit on the image is not that bad, it gives me (trusting LTSPice) 4,4mA per Diode at 4.2V and 9,8mA at 7,5V. It's not that bad, but I'd like the current difference between high and low volatge to be lower. Also, I imagine to use that circuit 2 times, one for each AC leg. Ok, I'll probably add a capacitor in order to reduce the flickering, but I don't have much space. I'll decide on the caps when I see the circuit in action. I'd be very glad for any suggestions! Dominique |
It sounds like your circuit would be suited to a switching voltage regulator. These basically provide a certain output voltage even when the input varies within some voltage range. they're called 'boost' regulators if the output voltage is always higher than the input, 'buck' if it's lower, or boost-buck if the output voltage is somewhere in the middle of the input voltage range. Depending on how you drive your LEDs you could probably use any of those configurations; in fact, if you are really set on a constant current source, you could use a boost regulator to increase the input voltage to drive your current source with a higher voltage so you didn't need to worry about dropout.
EEgeek.net |
I agree that a switcher would be more efficient. Here is an idea that doesn't require one, but of course is not so efficient: (Save the code as "filename.asc" if you don't want to have to redraw the schematic.)
Version 4 SHEET 1 1120 724 WIRE 80 176 80 80 WIRE 80 336 80 256 WIRE 80 352 80 336 WIRE 240 80 80 80 WIRE 240 608 240 80 WIRE 320 80 240 80 WIRE 320 608 240 608 WIRE 464 80 384 80 WIRE 464 192 464 80 WIRE 464 336 80 336 WIRE 464 336 464 256 WIRE 464 432 464 336 WIRE 464 608 384 608 WIRE 464 608 464 496 WIRE 672 80 464 80 WIRE 672 160 672 80 WIRE 672 288 672 256 WIRE 672 352 672 288 WIRE 672 480 672 448 WIRE 672 608 464 608 WIRE 672 608 672 560 WIRE 848 288 672 288 WIRE 912 80 672 80 WIRE 912 112 912 80 WIRE 912 208 736 208 WIRE 912 208 912 192 WIRE 912 240 912 208 WIRE 912 368 912 336 WIRE 912 400 736 400 WIRE 912 400 912 368 WIRE 912 448 912 400 WIRE 912 608 672 608 WIRE 912 608 912 576 WIRE 976 368 912 368 WIRE 1040 80 912 80 WIRE 1040 224 1040 80 WIRE 1040 368 976 368 WIRE 1040 368 1040 304 FLAG 976 368 D2 FLAG 80 352 0 SYMBOL voltage 80 160 R0 WINDOW 123 0 0 Left 0 WINDOW 39 0 0 Left 0 SYMATTR InstName V1 SYMATTR Value SINE(0 4 30) SYMBOL pnp 736 256 R180 SYMATTR InstName Q4 SYMATTR Value 2N3906 SYMBOL pnp 848 336 M180 SYMATTR InstName Q5 SYMATTR Value 2N3906 SYMBOL res 896 96 R0 SYMATTR InstName R3 SYMATTR Value 33 SYMBOL LED 896 448 R0 WINDOW 3 81 42 Left 0 SYMATTR InstName D3 SYMATTR Value QTLP690C SYMATTR Description Diode SYMATTR Type diode SYMBOL LED 896 512 R0 WINDOW 3 82 41 Left 0 SYMATTR InstName D4 SYMATTR Value QTLP690C SYMATTR Description Diode SYMATTR Type diode SYMBOL npn 736 352 M0 SYMATTR InstName Q6 SYMATTR Value 2N3904 SYMBOL res 656 464 R0 SYMATTR InstName R5 SYMATTR Value 4.7k SYMBOL res 1024 208 R0 SYMATTR InstName R6 SYMATTR Value 100k SYMBOL diode 320 96 R270 WINDOW 0 32 32 VTop 0 WINDOW 3 0 32 VBottom 0 SYMATTR InstName D1 SYMATTR Value 1N4001 SYMBOL polcap 448 192 R0 SYMATTR InstName C1 SYMATTR Value 1000µ SYMBOL polcap 448 432 R0 SYMATTR InstName C2 SYMATTR Value 1000µ SYMBOL diode 384 592 R90 WINDOW 0 0 32 VBottom 0 WINDOW 3 32 32 VTop 0 SYMATTR InstName D2 SYMATTR Value 1N4001 TEXT 70 432 Left 0 !.tran 100m |
Here's simpler:
Run the AC into a full wave bridge, filter it to DC, and run each LED on a separate current source. Each current source is a bipolar with a resistor in the emitter, bases tied together. and shunted to ground through a third transistor collector to ground. The third transistor's base connects to one of the emitter resistors of the current driver transistors. One resistor to +V provides base drive and the LEDs are one in each collector of the CC transistors. That should do it. Those CCs will saturate to under 1V if you use reasonably high gain/high current devices.
R.G. |
A thousand pardons if this is not what you described. |
Yeah, that's the circuit I had in mind.
Maybe I'm reading his notes wrong. I was using 4.2Vrms in the sim, and it worked fine and dandy. I went back and put in 2.97vrms/4.2V peak and got about 15ma on each LED. That may or may not be enough for the application. It pulled out of CC regulation for 20ma at about 4.7Vpk/3.3Vrms. But it was still about 15ma. The real question here I think is what's the internal regulation of the source? If it's got a good low internal impedance, either way works - yours certainly and mine almost. If it's got say, 5 ohms internal impedance, my way sags to about 12ma and yours is just beginning to pull out of regulation. So I think the doubler is much more constant current. It's a tradeoff between two additional diodes to make a bridge and one additional capacitor for the doubler, with better performance on the doubler. The FWB will be fine with 1000uF, so the caps can be the same size as well.
R.G. |
I think Ron H's idea of a 1/2 wave voltage doubler is great. Add a LM317L
Z (To-92, 100Ma) adjustable regulator with a 62 ohm resistor between the out terminal and the adjust terminal will create a 20 Ma constant current source. Connect the LED's series from the adj terminal and the - point of the voltage doubler output. The input of the regulator to the + of the voltage doubler. Less parts and simpler.
The great thing about electronics is unlimited ways to do the job. The only limit is one\'s imagination. I generally think my way is best. Show me a different way. I have an open mind. |
Quite simply, I think the idea of splitting the two LEDs into separate legs of the current source is brilliantly simple, and I smacked my forehead the moment I read it for not thinking of it myself! :lol:
EEgeek.net |
unexpectedly I was away for two days, and now I'm very glad to come back and find your helpful answers. Thanks already and see you soon! Dominique |
Hey,
I don't feel comfortable now: You've put your ideas in here, and Ron has even made those schematics and simulations (Wasn't there a saying: "A Schematic tells more than a 1000 words") I thank you very much! And those are good ideas! Unfortunately both circuits are less efficient than what I'm looking for. Mostly, the voltage will be 6V and therefor, I'd really like to use more than 2V (as in the "one LED per regulator" suggestion) of it. Of course, your suggestions are very good in case of low voltage, but I hoped for a solution with simply a lower voltage drop than my circuit. I also tried a voltage doubler version with a reg1117: very simple, but it seemd to draw a lot of current from the voltage source! Maybe I'll have to try the circuits for real now. Whenever in the simulation I used capacitors to even out the DC, the currents were very high. Ok, that's normal, but when I made an average current out of it (after the caps were fully loaded of course) by view and by measuring, the average was way higher than expected and than in the version without caps! I don't remember exactly, but the loss was in the range of 1/3 or even 1/2, that's something I don't understand. Those standard capacitors don't waste that much energy, do they? In addition, I'll look for a step-down regulator circuit, which hopefully regulates the current at the same time as being simple! Thanks again, Dominique |
To make it more efficient would probably require moving to switch-mode designs, greatly increasing the complexity - which probably isn't worth it for lighting a couple of LED's? - you wouldn't notice any change in the pedal power required!. |
