Hi, I have a 2n3055 transistor which I am going to use in a darlington pair arrangement with a BC107. The 2n3055 is in a to3 case which I am not familiar. The transistor only has two legs, E and B and the case is C. Do I need to heatsink this device? What would be the best way of doing this? Also what would be the best way to connect the collector to the PCB? Thanks, Tom | |
| | #2 | |
You need to mount the transistor on the heatsink with an insulating kit, these contain a mica or silicon washer, and two plastic insulators for the bolts. If you use a mica washer, you should smear each side with heatsink compound, which is freely available (as are the mounting kits). You connect to the collector with a soldering tag fastened to one of the bolts through the plastic insulators. | ||
I think that a little BC107 will burn out or melt if it tries to drive a 2N3055. At 10A, the 2N3055 has a min current gain of only 5, so the little BC107 will smoke trying to drive 2A.
BJT's are terrible for high current... For a lot of applications, a transistor in the TO-92 package will drive a '3055 just fine (lower current / higher voltage applications). As for the heat sink, you need to know how much power that transistor is absorbing. There are "thermal resistance" values on the transistor's data sheet, as well as the datasheets for the heat sinks and mica pads. If you add up all of those, you'll get a total thermal res. from junction to air--multiply this by the power going into the transistor and add it to the expected ambient air temp. to get the junction temperature. BE SURE that the power dissipation you calculated is below the "derating" value given on the data sheet for the junction temp you calculated! | |
| | #5 | |
| | #6 |
You can find 2N3055 whith up to ganin of 15. Also MOSFETs come to mind.They have chanel resisstance insted of forward voltage like BJTs do.Also they are voltage controled and make much less heat but they are slow.
| | #7 | |
But what if you ordered some from your supplier and they were all made at the same time late on a Friday? Then their gain would be only 5, wouldn't it? Would they have any gain if they were made early on a Monday? A 2N3055 transistor is rated for 15A. The datasheet doesn't list currents higher than 10A. Does it need 7A of base current (its max) to get 15A of collector current? If a manufacturer shows on the datasheet that a transistor is guaranteed to have a gain of 5 or more, then I design the circuit so it will work with any transistor that meets that spec.
| | #8 | |||
For the "high current" values people are likely to bring up here, MOSFETs are easier to deal with (even though a BJT can have a higher max rated current). For truly high-current power electronics (pretty much anything over 100A), you'd want to use SCRs or IGBTs. Quote:
| | #9 |
MOSFETs can switch more curent than BJTs.This is becose they can go down to miliohms of full on resistance.BJTs are above 1 volt so at high curent an BJT will act more as a load and so making heat and too much heat sends semiconductors in silicium heaven. The problem whith MOSFETs is there big gate capacitance.So you end up driving an voltage controled MOSFET whith somthings that can output amps of curent.Becouse if you charge the gate slow the MOSFET will be more of the time in that half conducting state in this state a lot of heat is made.So an better drive cirucit will make the MOSFET run cooler in high freq.
| | #10 |
Hi, I have a 2n3055 transistor which I am going to use in a darlington pair arrangement with a BC107. The 2n3055 is in a to3 case which I am not familiar. The transistor only has two legs, E and B and the case is C. Do I need to heatsink this device? What would be the best way of doing this? Also what would be the best way to connect the collector to the PCB? Thanks, nasib rahim+92555939555213 | |
| | #11 |
2N3055 Θjc = 1.5°C/W, max junction temp = 200°C, so with a perfect heatsink you can dissipate (200-25)/1.5 = ~120 W. Figuring out Θca for power transistor packages is a little tricky, but somebody might have measured or calculated it and posted it on the Web. Here's a link with data on a TO-220 package http://www.ichlc.com/doc/TJ3965.pdf with Θja = 75°C/W and with a max Tj of 125°C. By scaling up from the surface area of a 220 package to that of a TO-3 and neglecting Θjc for the 220 you could guesstimate all the thermal resistances you need for a TO-3 package. If the TO-3 package has four times the surface area of the TO-220 package, Θja = 1/4 *75°C/W = ~20°C/W. For Tj max = 200°C you could dissipate (200-25)/20 = ~9 W in the TO-3. Last edited by Willbe; 12th September 2008 at 11:12 PM. | |
| | #12 |
Hi Nasibrahim, Whether a transistor requires a heatsink or not will depend on the total power dissipation of that transistor in that particular application and this applies to all transistors. ![]() If you want to mount a transistor in a TO-3 housing directly on a pcb you need to drill two 3 or 4 mm holes in the pcb and bolt it (together with it's heatsink) to the pcb. Also make the copper tracks wide enough to solder the nuts directly to the pcb. on1aag. | |
| | #13 |
They make board level heatsinks specifically for TO-3 devices if you are dissipating low power. An easier device to heatsink/mount is the TIP3055. It comes in a TO-18 package which is like a large TO-220. Easy to mount to a heatsink. | |
| | #14 | |
http://www.onsemi.com/pub_link/Collateral/2N3055-D.PDF
__________________ I do not answer private messages asking for help because no one else can: benefit from advice I may give or correct me if I'm wrong. Please ask on the open forum if you have a question and I'll be happy to help, if I know the answer. | ||
| | #15 |
Interesting - a look at the datasheet table suggests a gain of 5 at 10 amps - the graph suggests a gain closer to 10. I would not claim to be skilled at reading the datasheets - just pointing out what I see in hopes that a comment or two might improve my ability to interpret the datasheets.
__________________ stevez | |
| heatsink |
