http://en.wikipedia.org/wiki/Siemens_(unit) |
yea i did but i still don't really understand what transconductance is
Because tube transconductance is different than transistor transconductance VS OTA transconductance VS FET transconductance What are the 4 transconductance differences between all these Tube transconductace? Transistor transconductance? OTA transconductance? FET transconductance? What are the differences please? Transconductace means transfer conductance but also means Controlled conductance |
i don't know can u please tell me because i don't know
"Because tube transconductance is different than transistor transconductance VS OTA transconductance VS FET transconductance" thats y i asked , how do they differ.? |
TUBES:
transconductance is the change in the plate(anode)/cathode current divided by the corresponding change in the grid/cathode voltage, with a constant plate(anode)/cathode voltage. Typical values of gm for a small-signal vacuum tube are 1 to 10 millisiemens. FETS: in field effect transistors, transconductance is the change in the drain/source current divided by the change in the gate/drain voltage with a constant drain/source voltage. Typical values of gm for a small-signal field effect transistor are also 1 to 10 millisiemens. TRANSITORS: The gm of bipolar small-signal transistors varies widely, increasing exponentially with the emitter current. It has a typical range of 1 to 400 millisiemens. The input voltage change is applied between the base/emitter and the output is the change in collector current flowing between the collector/emitter with a constant collector/emitter voltage. A transconductance amplifier outputs a current proportional to its input voltage. OTA: What are the differences? and why are the transconductance different? |
i don't understand where is the difference..
transconductance is the change in o/p current wrt change in i/p voltage . for each of the above devices the i/p and o/p method/pins(whatever u call it) may be different . it doesn't mean the gm is different . |
oh sorry i thought the (gm) would be different because of the different millisiemens from input to output
Because i thought the millisiemens (gm) is different from input to output for a tube VS OTA VS transistor VS FET |
Typical values of gm for a small-signal field effect transistor are also 1 to 10 millisiemens. Typical values of gm for a small-signal vacuum tube are 1 to 10 millisiemens. See the bold see the difference of (gm) ? of the millisiemens why are they different? |
