| What is Curve Fitting? here is a site: http://archives.math.utk.edu/visual....0/curve_fit.5/ Parallel resistance changes the "wiper resistance" per shaft rotation? ( curve of resistance versus shaft rotation) 1.) approximate log 2.) approximate reverse log 3.) approximate exponential 4.) approximate square-law pattern What are the tappering values for each types? | |
| Curve Fitting is a way of changing the voltage-divider action of a linear potentiometer to approximate a logarithmic pot for use as a volume control. You add a resistor to ground at the slider of the pot.
| Thanks for the help How do i get a exponential curve? How do i get a square-law pattern curve? | |
| Adding a resistor to the slider of a linear pot only approximates a logarithmic response. I don't know how to make it approximate other curves. I figure that if you need a log pot then buy one, instead of fiddling with a linear one.
| But how do i get a exponential curve pot ? and a square-law pattern curve pot ? who makes them please? | |
Least squares is commonly used in matrix algebra when a solution does not exist. A least squares solution is guaranteed to exist so in some cases it is advantageous to use it. | ||
| To be a bit more broad, curve fitting is the calculation of a line/parabola/higher degree equation that fits a set of data. Curve fitting can be useful for predicting possible outcomes. For example, I could have data for prices of a certain make of car from the past ten years. On a graph, I would have price on the Y-axis and year on the X-axis. The price for each year would be a point on the graph. Now, let's say I want to find out what the car will roughly cost ten years from now. I use curve fitting (I do it on my graphing calculator (TI-86)) and pick an appropriate curve depending on what the data looks like (this assumes you're famillar with the standard graphs for various equations.) Now, I can fit a line and a second degree equation (largest exponent on a variable is 2) and see which curve fits better (gets closer to more of the points.) Curve fitting in a nutshell.
__________________ -Ian | |
| my Vox wah wah pedal is design for exp and square curves pots only i need one not linear or log | |
| someone told me to use a spreadsheet problem to do curve fitting | |
| how do u find out what curve to use or design it to a circuit? | |
| Walters, Do you want to play with numbers or do you want to replace the worn-out pot in your wah-wah pedal? You could also copy or design a new wah-wah circuit that uses an ordinary linear or log pot. What do you want to do? :?:
| i want a square root pot curve how do i get it please | |
| Walters, You get the replacement pot for an old wah-wah pedal from a guy who makes and sells copies of the pedal. Look in Google for Wah-Wah Pedal. A link has the history and an article all about them. One guy wanted to get rich by making and selling new wah-wah pedals that sound exactly like the old ones so he tried pots from 8 manufacturers with all the tapers they made. The pots were different so he ordered some custom-made pots that were identical to the original old pots. The guy who makes copies of the old wah-wah pedals might not sell just a pot. He wants to get rich so he will probably try to sell his extremely expensive entire pedal. Then if you are rich and want to make and sell wah-wah pedals to become richer, you could order a few thousand custom-made pots yourself. :lol: Quote: "The subject of potentiometers also warrants another look. Numerous differently tapered pots found their way into use in the THOMAS/VOX wahs. These included, but were not limited to: Allen Bradley Type J, Allen Bradley Type EJ, Centralab (two different, non-labeled tapers), Clarostat EJ, Clarostat J, Clarostat NP, Ohmite AB, Alpha, ERT, ICAR, and FRT. The unofficial "right" pot was the ICAR. This unit did not have a standard type taper. Because of this, the effect achieved while using an ICAR pot was unlike that achieved using a more standard (U.S.) pot. The ICAR was pretty much in a class by itself. Interestingly, Centralab offered a pot in Europe that almost duplicated the ICAR, but apparently, they did not sell it in the U.S. Since the ICAR pots have been unavailable for years, I've had a number of 100% accurate pots manufactured for my use in my tunable RMC3 wah."
