+ Reply to Thread
Results 1 to 11 of 11
Thread: Comment on this Circuit
  1. #1
    akg
    akg is offline
    akg Newbie
    Join Date
    Sep 2005
    Location
    India
    Posts
    1,406
    Default Comment on this Circuit
    Hi all..
    some threads below . 'audio' has posted a ckt of RF Tx using logic chips
    now i think this ckt is really ingenious in the design.. using chip that is never intended to use like that...
    what do u think ? ....
  2. #2
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,870
    I don't think a crystal mic has enough current to force the input of an LsTTL gate low.
    I don't think a Schmitt trigger inverter will oscillate with its input directly connected to its output.
    Maybe miracles happen.
  3. #3
    akg
    akg is offline
    akg Newbie
    Join Date
    Sep 2005
    Location
    India
    Posts
    1,406
    Quote Originally Posted by audioguru
    i was also confused by the usage of schmitt triggered ttl , but his website says "it works" .. :roll: ... hmmm..
    visit http://www.uoguelph.ca/~antoon/circ/uspy3.htm
  4. #4
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,870
    Quote Originally Posted by akg
    Watch out for circuits on the web. Maybe his wire from the output of the Schmitt trigger inverter to the input had resistance. Then it would oscillate.
    I spotted one of his FM transmitters with its preamp transistor incorrectly biased. Maybe he connected it with its collector and emitter wires reversed by mistake, then the transistor's current gain would be low and the transistor would work.
  5. #5
    Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent
    Join Date
    May 2003
    Location
    Idaho, USA
    Posts
    6,723
    I'm betting it works.
    Anybody have a 74LS13? 74LS132?
    Ron
  6. #6
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,870
    I guess the output of a 74LS13 must have some output resistance that would allow it to oscillate. Right?
  7. #7
    Join Date
    May 2003
    Location
    Idaho, USA
    Posts
    6,723
    And propagation delay. Note the tuning capacitor on the output which uses the output resistance to create variable delay, and hence variable frequency.
    Ron
  8. #8
    akg
    akg is offline
    akg Newbie
    Join Date
    Sep 2005
    Location
    India
    Posts
    1,406
    as far as i know.. electronics is a science.. so is there any chance for miracles ?? if it works then there should be some reason .. the best thing would be to test it..does any one has the ic , and a 5min to spare?? . (i have time but no ic :wink: )
  9. #9
    eblc1388 Excellent eblc1388 Excellent eblc1388 Excellent eblc1388 Excellent eblc1388 Excellent
    Join Date
    Jan 2005
    Location
    UK
    Posts
    2,226
    Certainly, according to Mr. M.... :shock:
    L.Chung
  10. #10
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,791
    Quote Originally Posted by eblc1388
    A miracle is simply something you don't understand YET! - so there's certainly scope for them in electronics.
    As regards the circuit above, the chances of it working depend entirely on what's inside the 'little plastic box with legs on' - it's entirely possible that some makes of 74LS13 may work? - but using a logic chip in this kind of way is completely dependent on how it's constructed, and different manufacturers will make them differently.
    But it's such a crap circuit anyway!, even if it worked it's only a novelty.
  11. #11
    akg
    akg is offline
    akg Newbie
    Join Date
    Sep 2005
    Location
    India
    Posts
    1,406
    Quote Originally Posted by Nigel Goodwin
    hmm...... :roll: ....u r a veteran so no arguments...
    i'll have a check ... :?
+ Reply to Thread
Tags for this Thread
