I still don't get have PWM can make a (pf) Varactors into a (uf) varactors?
Uncle $crooge |
(permalink) | ||||
Uncle $crooge |
sorry i ment
Varactors in "parallel " to increase the capacitances? |
Uncle $crooge |
PWM have duty cycle which changes the time constant of the Varactor capacitance
Varactor diodes use a DC voltage or modulated DC voltage to change their tiny value, not PWM. The tiny value of varactor diodes is useful only in radio circuits. I thought you are working with audio circuits using capacitor values that are thousands of times greater than varactor diodes. So forget about varactor diodes for your circuit.
Uncle $crooge |
(permalink) | ||||||
omg! That means you will need at least 100,000 diodes in parallel that can produce a 10pF capacitance! By the time you inserted the 100,000th diode, you would probably have ran to us again :lol: Quote:
Why not increase the resistors that also affect the frequency you are dealing with so that you can lower the capacitance? Increasing resistors can help reduce power requirements and potentially extend battery life.
-=: The best low-priced components to troubleshoot with are the speaker and the LED :=- |
I am glad to see that you have learned a lot and truly understand these things. :lol: :lol:
Uncle $crooge |
(permalink) | ||
Still, as they say, "a little knowledge is a dangerous thing!". |
(permalink) | ||
(permalink) | ||
maybe you are right.
Maybe Walters wants to confuse everybody, including himself! :shock:
Walters is confused because he wants to make electronic wah, wah sound effects mechanically in his 50 year old Leslie rotating speaker, by modulating its speed with exotic waveforms.
I think he also wants to make the Leslie speaker's sound electronically. He also wants to fix his worn out 50 year old wah, wha pedal, but its special pot isn't available so he wants to convert an ordinary pot. It would be confusing to a nooby and to an engineer to analyse the rotating phase shifts and Doppler FM effects of a Leslie speaker, then try to make the same sound and new ones with opamp variable allpass filter circuits. If I had a guitar then I would also try to make the sound electronically, but I would probably use DSP instead of millions of opamps. It boggles the mind, doesn't it? :lol:
Uncle $crooge |
