Old 10th January 2006, 02:19 AM   (permalink)
Default transistors
It might be a stupid question but i'm new to electronics, How do you know what kind or type of transistors you need to use in a certain circuit?
tj107us is offline
Old 10th January 2006, 02:33 AM   (permalink)
It depends on a number of factors:
#1. What technology of transistor is best for the circuit? FET, BJT, etc.
#2. If you are using BJT's What polarities do you use more often? This determines whether you should use NPN or PNP more often.
#3. Look at how the transistor is made. a BJT transistor contains two diodes back-to back. This greatly determines what kind of transistor you use.
What is the "certain" circuit you are referring to?
-=: The best low-priced components to troubleshoot with are the speaker and the LED :=-
mstechca is offline
Old 10th January 2006, 02:44 AM   (permalink)
Thanks alot?
tj107us is offline
Old 10th January 2006, 03:17 AM   (permalink)
Originally Posted by tj107us
Thanks alot?
Very appropriate punctuation.
Some of that was true, some was mumbo-jumbo. Unfortunately, he sometimes has a tendency to do a core dump when he sees something that he's had some experience with.
Your question doesn't have a simple answer. It takes a lot of education and/or experience to design a working circuit. If you're new, you will learn faster by copying proven designs and attempting to understand how they work.
Ron
Roff is offline
Old 10th January 2006, 03:50 AM   (permalink)
I had to make my point. Otherwise he could ask more.
Thats why I gave the three points.
Start with the easy designs, and when you understand with the easy designs, go with some more difficult ones. It does take research to be experienced.
mstechca is offline
