Alnico magnets are used for guitars alots but there is different mixtures
like Alnico I-II-III-IV-V different mixtures of Alnico Is a magnet the same as a inductor ? i don't get about these different types of mixtures because they all have different frequency responses why is that and how can u tell about a magnets frequency response? a Magnet with wire turns around a pole = a coil Whats the theory on Electro Magnets? im new to this stuff Because winding the wire about the magnet can produce different frequency responses, Q points, resonances, midrange boost or midrange peaks how? |
(permalink) | ||
At a basic point of view, an inductor is a piece of wire wound many times. I'm not going to explain what a magnet is because you should know what a magnet is. When an inductor is used in an electronic circuit, it produces a magnetic field. Quote:
-=: The best low-priced components to troubleshoot with are the speaker and the LED :=- |
A magnet is not usually wound to make an inductor. An inductor core is made out of a magnetic iron-based material but it is designed to not be permanently magnetized. It gets temporarily magnetized when current is passed through the coil.
When you have a moveable permanent magnet move inside a coil, the changing magnetic field creates current. That's how motors and the non-condensor type microphones work. A permanent magnet doesn't really have a frequency response since it only creates a constant field. That being said, I can't rule out subtle nuances in its properties that would affect the frequency response of a speaker.
I thought what I'd do was I'd pretend I was one of those deaf-mutes. |
(permalink) | |||
at least the coil is responsible for providing the inductance value.
What is a magnet then is it a LCR network?
Because there is different mixtures when making magnets what does this do ? Magnets have different frequency responses from different mixtures why is that? How can a magnet have different frequency responses? what kind of component is a magnet a inductor,resistor,cap? |
(permalink) | |||||
an LCR network is an inductor, capacitor and a resistor connected together in some way, shape, or form. Quote:
Thanks for correcting me
How to change the magnetic field? How to change th flux? How do change the permeability? When winding a wire around a magnetic it creates a magnetic field and then the magnetic and wire from a electromagnetism? a Coil and a magnet from a current, so changing the flux changes the magnetic field changing the current? It seems like magic from just taking a magnet and wrapping a wire around it forms a magnetic field and flux and having a current output It seems like a magnet is a voltage generator? Its seems like a coil and magnet form a current generator? |
Is the magnetic Field and Flux the same thing whats different about them?
Is The permeability a magnetic field or flux? What is a permeabiltiy? |
It'd be hard to explain it, magnetics requires some physics understanding. Lots of web pages can give you an explanation with pics and such.
Understand that permanent magnets are very different things compared to magnetic materials such as used in transformers and inductors. In the transformer, you want to use a coil to change the magnetic flux in the core. A permanent magnet has a fixed, built-in flux that resists change. A wire in a changing magnetic field produces current. This is not free power though. One way to do this is moving a permanent magnet past a coil (or vice versa). It's not free because when power is drawn off it there will be "drag" force between them which slows down the moving object. The other common use is a transformer where there's no motion between the core and the coils. The first coil produces a varying magnetic field so the second coil will experience a changing magnetic field thus produce its own current.
If you want to make voltage, take a motor, and an LED. Connect the LED to the motor. you need to attach the motor to something that spins. Hey, why not take a bicycle, and attach the end of the motor to it. When you ride your bike, the motor spins, and the LED lights (if the motor is spinning the right way). Go faster, and the LED goes brighter. I shall compliment you for the fact you love exploring objects, but I think you are asking about stuff that doesn't really matter. Are you doing a project on magnets for school?
thanks guys for the help no not school work just need help
so whats the difference betwen a inductor VS a magnet? a coil is a magnet with wire wrapped around it which is a inductor? A inductor has Flux and a magnetic field? A magnet has Flux and a Magnetic field but whats the difference from a inductor they seem like the same thing |
why does the magnetic and wire wrapped around the magnetic cause a resonance frequency?
Hi Walters,
I think you are talking about a magnetic pickup for a guitar that has steel strings. When the steel string vibrates near the pickup, an AC voltage is generated in the coil that is wound around the magnet, because the magnetic field from the magnet is disturbed by the string. The coil has inductance and capacitance in parallel so therefore causes resonance. Additional capacitance can be added in parallel to reduce the frequency of the resonance. The load resistance for the pickup can be reduced to damp resonance or increased to allow resonance.
Uncle $crooge |
The coil has inductance and capacitance in parallel What is the inducatanc and capacitance? Is the inductance the magnetic? is the capacitance the magnetic or gauge of wire? |
So the Magnet = is a inductor because of flux,magnetic fields like
a inductor The Guage of wire- is the capacitance The wire windings- is the resisantance Total= LCR= DC resistance= impedance= Resonance Frequency >? If fender used Alnico 5 then this is a constant FIXED The only difference is the winding differences and gauge of wire so L = magnet= constant C= wire guage R= Winding differences |
