Old 20th December 2005, 02:22 PM   (permalink)
As previously mentioned you want an NE567 tone detector PLL IC - simple to use, and does just what you need.
Old 21st December 2005, 01:08 AM   (permalink)
I'll try it then. thanks.
-=: The best low-priced components to troubleshoot with are the speaker and the LED :=-
mstechca is offline   Reply With Quote
Old 21st December 2005, 02:18 AM   (permalink)
You will need several 567s to cover the range. I worked up a design using the CD4046, it takes 3 circuits to cover the range of 1 hz to 1kHz. If you build it, please let me know how well it works. Oops I forgot, use a coupling capacitor to pin 14 unless the signal is logic level.
Russlk is offline   Reply With Quote
Old 21st December 2005, 05:39 AM   (permalink)
akg
i was wondering that, is (s)he is trying to cover the entire range of 1hz to 1K using PLL(s)!!
akg is offline   Reply With Quote
Old 21st December 2005, 08:12 AM   (permalink)
No, he's only wanting to detect a single frequency, either ON or OFF, the (rather silly) range he specified was only so he could try for the optimum frequency.
Old 21st December 2005, 08:28 AM   (permalink)
akg
hmmm....
" You will need several 567s to cover the range. I worked up a design using the CD4046, it takes 3 circuits to cover the range of 1 hz to 1kHz. ""..
this comment inspired me to think like that..
Old 2nd June 2008, 03:01 PM   (permalink)
Default It is possible
yes you can make a pll with a 555, but i doubt that in the frec that you want to, thas was my first desing of pll, a xor gate, a low pass, an amplifier, an that was done, i was quite amazed, was in lock even when they have differen duty cycles, in this case you may do it, digitally, with a rate of meassure, with a computer, example if you want to buil a tacometer.
Gaddy Alcalą
Gaddy is offline   Reply With Quote
Old 2nd June 2008, 03:04 PM   (permalink)
with a PIC, maybe 1hz is too much
