Notices
Old 11th December 2005, 07:22 PM   (permalink (permalink))
Default analog function generator theory schematic
Where can i find schematics for analog function generators and analog Arbitrary function generator schematics?
Whats the block diagram of a analog fucntion generator and a analog arbitrary function generator ?
Its like VCO>>>wave-generating functional blocks?
I'm trying to learn the Stages/blocks inside a function generator and a Arbitrary function generator what are they from each stage until the output?
walters is offline
Old 12th December 2005, 07:14 PM   (permalink (permalink))
try looking up the 8038 IC it is quite useful in making a simple function generator
my site:www.simons-photography.com
http://rushdenrotaract.org.uk
see also
http://www.bigstockphoto.com/account...fid=m2URATYch5
http://www.redbubble.com/people/simonsphotography
Thunderchild is offline
Old 12th December 2005, 10:23 PM   (permalink (permalink))
chips like 8038 are not arbitrary function generators. they simply generate predefined functions using VFO and signal shaping/conditioning.
arbitrary function generators can produce any shape of signal user wants (programs it). simple approach is to have oscillator of variable frequency (clock) driving counter. counter outputs are used to address memory location (incrementing/decrementing). value from addresses memory location is converted to analog signal (DAC). memory can be (E)EPROM for example but this is not convenient way of changing program (wave shape). it is common to use MCU for example. this way MCU can communicate with computer to receive new programs.
panic mode is offline
Old 12th December 2005, 11:10 PM   (permalink (permalink))
Where do i find these circuits signal shaping or wave shaping circuits or stages
I can't find wave or signal shaping circuit schematics that are analog like in function generators
walters is offline
Old 12th December 2005, 11:32 PM   (permalink (permalink))
I'm kinda confused.
but if you are looking for a circuit that produces a wave, you are looking for an oscillator, or anastable multivibrator.
Do a search on oscillator and you will get your answer.
-=: The best low-priced components to troubleshoot with are the speaker and the LED :=-
mstechca is offline
Old 12th December 2005, 11:40 PM   (permalink (permalink))
No not the oscillator or VCO part the waveshaping stage AFTER the VCO or oscillator because all a oscillator or VCO does is produce square,sine,triangle and then Waveshaping or signal shaping stages,circuits,blocks change it
walters is offline
Old 13th December 2005, 01:06 AM   (permalink (permalink))
they only make basic changes (saw tooth, rectangle, etc.).
it is impossible to make analog device that will allow any desired signal shape on the output. this is why arbitrary function generators are using digital technology and lookup tables. you can make simple analog generator using oscilator, counter(s) such as 4017 and connect potentiometer to each output. connect all wipers through diode to comon point and amplify signal with an opamp for example. with each potetiometer you can adjust amplitude of the output signal for one single step. depending on number of steps you could have more or less complex output.
Old 13th December 2005, 01:18 AM   (permalink (permalink))
So you saying to hook up like 4 function generators and get a Summing amp or mixer to sum or mix different sine/triangle/square waveforms to create complex waveforms?
walters is offline
Old 13th December 2005, 12:30 PM   (permalink (permalink))
no,
do you understand concept of "lookup table"?
Old 13th December 2005, 01:36 PM   (permalink (permalink))
Hello,
I made one using the I.C. XR2206 and I have sinoidal, triangle and rectangle. I have the schemes on a book...
Regards from Mallorca.
YouŽll never know enough...
2PAC Mafia is offline
Old 13th December 2005, 01:55 PM   (permalink (permalink))
The schematics for the ICL8038, MAX038 and XR2206 function generator IC circuits are in their datsheets. Frequently an entire project is shown with parts lists having manufacturer's part numbers and even a pcb layout. They also describe how they work with good detail.
audioguru is online now
Old 13th December 2005, 10:10 PM   (permalink (permalink))
I saw once on Harry's homebrew homepages that he uses an EPROM to create a customized wave. This may be similar to what you require.
Do a google search for "Harrys homebrew" and go to the projects, and then EEPROM circuits section.
mstechca is offline
Old 16th December 2005, 03:01 PM   (permalink (permalink))
yep, that's a very simple one:
http://web.telia.com/~u85920178/eprom/epromosc.htm
Old 16th December 2005, 04:28 PM   (permalink (permalink))
Take a square wave, a perfect one from a digital divider, and feed it through an 8th-order switched-capacitor Butterworth lowpass filter IC and the resulting sinewave is nearly perfect with only about 0.05% distortion.
Take a clock frequency that is 10 times higher than the output and clock a CD4018 Johnson "walking-ring" Counter with 4 output resistors to make a stepped sinewave that is actually oversampled. Feed it through an 8th-order switched-capacitor Butterworth lowpass filter IC and the resulting sinewave is perfect with unmeasurable distortion, like I have in my audio generator. The counter and resistors perform like the ones in Harry's Eprom circuit. :lol:
