Old 6th December 2005, 08:11 AM   (permalink)
Default TDA2003 Amplifier
Speaker connect to TDA2003 Amplifier shall be connect to output (pin 4) and refer to ground.
What happend for abnormal design, where the speaker is refer to +12V?
I have test it, it work well.
But I would like to know if I will get into problem after a long run for this abnormal circuit?
( I connect to +12V is for compatible on existing speaker setup which prefer not to change.)
Thank you,
VictorPS is offline
Old 6th December 2005, 08:59 AM   (permalink)
i don't think it will cause problems ..
since it is dc decoupled/ ac coupled . only difference shld be that when viewed thru oscilloscope , the waveforms are 180 degree out of phase.
akg is offline
Old 6th December 2005, 09:22 AM   (permalink)
Default Re: TDA2003 Amplifier
It makes NO difference if you connect the speaker to positive or negative (signal wise they are both identical) - BUT you MUST reverse the direction of the speaker coupling capacitor C14, as it's then connected the wrong way round!.
BTW, there's nothing 'abnormal' connecting a speaker this way, it's fairly common practice!.
Old 6th December 2005, 10:41 AM   (permalink)
is there any preferance/ advantage when connecting like this?..or is it done when the layout matters ?
akg is offline
Old 6th December 2005, 11:05 AM   (permalink)
The usual advantage (although it doesn't apply in the case of this IC) is that it can save you a boot-strap capacitor, the speaker coupling capacitor can be used to boot-strap the top output transistor, saving a seperate capacitor. You used to see it done a lot in low priced record players and radios.
Old 6th December 2005, 05:08 PM   (permalink)
The TDA2003 is designed for high output current. An 8 ohm speaker doesn't need much current.
With the 12V supply, an 8 ohm speaker gets only 2W at an awful-sounding 10% distorted overdrive. At clipping it will be only about 1.5W.
Into a 1.6 ohm load (five paralleled 8 ohm speakers), the total power with 10% distortion is 8W.
audioguru is offline
Old 6th December 2005, 07:36 PM   (permalink)
Is this done this way to minimize the pop when the power is switched on?
Ron
Roff is offline
Old 6th December 2005, 07:44 PM   (permalink)
No, just to save a boot-strap capacitor (on amps that use them), there's no advantage on the TDA2003 circuit.
Old 6th December 2005, 11:08 PM   (permalink)
Thank you, will reverse polarity of C14.
How about C15 & R12, just leave it as it or refer to +12V?
VictorPS is offline
Old 6th December 2005, 11:10 PM   (permalink)
You can minimize the turn-on pop of a single supply amp like this one if you allow the input capacitor to charge slower than the feedback capacitor but only if the load is cap-coupled to ground.
I think this amp would have a terrible BANG when it is turned-on.
Old 7th December 2005, 04:58 AM   (permalink)
Is that pop caused due to initial charging of the i/p cap?, or does other capacitor in the ckt take its part ?
akg is offline
Old 7th December 2005, 05:16 AM   (permalink)
Since the input cap is discharged before the amp is turned on, when you turn it on then the input cap keeps the input voltage low until it charges, therefore the amp's output voltage is also low charging the big output cap suddenly through the speaker.
The pop will be much less if the speaker was connected to ground.
Old 7th December 2005, 09:33 AM   (permalink)
It doesn't really matter!.
Old 7th December 2005, 03:11 PM   (permalink)
I believe that we are assuming here that +12V is well-regulated and ripple-free. Any noise on +12V will show up across the speaker.
Ron
Roff is offline
Old 7th December 2005, 03:16 PM   (permalink)
Certainly!
And if the supply has some internal resistance then the amp will make motorboating sounds like crazy due to positive feedback.
