When measuring phase on the oscilloscope i see 2 waveforms one is leading or laging the other example 1:: Waveform#1 is 10us laging Waveform#2 What is the phase angle of 10us? how do i find the phase angle from a time measurement? Example 2:: Waveform#1 is 40ms ("laging") waveform#2 What is the phase angle of 40ms? How do i find the phase angle of 40ms? Example 3:: Waveform#1 is 40ms "Leading" waveform#2 What is the phase angle of 40ms? How do i find the phase angle of 40ms? See how the 40ms is the same distance from waveform#1 zero crossing point to waveform#2 zero crossing point but the only difference is the leading and laging this should give a different phase angle even tho it has the same 40ms time difference? | |
You can't determine phase angle w/o knowing the frequency my friend.
Do i measure waveform#1 total time measurement? to get the freq? and measure waveform#2 total time measurement? to get the freq? Or how do i get the frequency of the time difference between the two waveforms? | |
which type of wave form, sine?
two Sinewaves or two square waves or 2 triangle waves how do i measure phase from all 3 different forms please? What would be the difference from the type of waveform it is? Measuring frequency for a sinewave? Measuring frequency for a square wave? Measuring frequency for a triangle wave? isn't the same just measure the time for 1 cycle or period ? | |
| | #6 | |
V(t) = V(max) * Sin(wt + theta) w = 2*pi*f t is the time and theta is the angle so if u know f,t vmax etc. u can get the phase lag etc | ||
| | #7 |
Thanks for the help But with the oscilloscope all i can measure is the Time difference the time between the 2 waveforms Waveform#1 >>>40us>>>Waveform#2 I measured 40us on the oscilloscope so what do i do now? 40us is the time distance between the 2 waveforms | |
| | #8 | |
| | #9 |
So if i measure the frequency of waveform#1 and measure the frequency of waveform#2 where do i go from here example waveform#1 is 1K waveform#2 is 700hz time difference is 40us between waveform#1 and waveform#2 If i know the frequencys of the waveform#1 and #2 and i know the time difference is 40us what do i do know to get the phase angle? How do i know is waveform#1 is laging or leading? example waveform#1 is 500hz waveform#2 is 500hz time difference is 40us between waveform#1 and waveform#2 If i know the frequencys of the waveform#1 and #2 and i know the time difference is 40us what do i do know to get the phase angle? How do i know is waveform#1 is laging or leading? | |
| | #10 | ||
you know whether one waveform is leading or lagging the other by looking at the image on the oscilloscope. if a waveform is leading the other, it will appear to be shifted to the left of the other one. that might seem backwards at first glance but think about it a bit and it should make sense.
__________________ EEgeek.net | |||
| | #11 |
Just push the "measure phase" button. Thats much easier. Or learn how to do simple math.
| | #12 |
Thanks alot for the information and examples But how do you convert Time measurements like 40us to degrees? 600ms to degrees? 100us to degrees? 20us to degrees? 70ms to degrees? Because degrees is like a percentage? of 360degrees? | |
| | #13 |
you don't just "convert a time measurement to degrees", at least not just some arbitrary time period by itself... the phase angle only has meaning when you are talking about the time delay between signals with respect to the period of those signals. the phase is a percent of 360 degrees. the time delay between two signals is a percent of the period of the signals. and the percentages are equal. (time delay/period)=(phase angle/360 degrees) measuring on a scope, the time delay can vary between 0 and the period, thus making the phase angle vary between 0 and 360 degrees accordingly.
| | #14 | |
Thanks alot evandude for the help The period=360 degrees? This is a good formula Quote:
If the time delay is 40us the period is 100us phase angle would be 40us/100us= 0.4 percent? or degrees? | ||
| | #15 |
Well British Universities charge £1000 per year in Tuition fees (going up) for an electronic degree.... walters, it has already been said phase-shift is only relevant between waveforms of the same freq. Take a simple sinusoidal waveform Sin(wt) That has a freq of w Now lets take a waveform Sin(wt + a) THIS waveform now has a phaseshift of "a" radians w.r.t. Sin(wt). So say you have two waveforms of the same freq and you measure the time difference between them (say looking for the zero-crossings). you NEED to know the freq. Say you have a phase shift of 50us (measured from the scope) and the freq is 1kHz. The period for 1kHz is 1mS. 50uS is 5% of the total time period, so the phase shift in degree's is 5% of 360deg = 18deg THIS is true for any repeating waveform: Triangle, squarewave, complex AS LONG AS THE FREQ ARE EQUAL | |
| measuring, phase |
