Old 29th November 2005, 03:53 AM   (permalink)
Default different power supplys currents Why?
Why do some products use Center Positive VS center Negative ?
Why would a designer choose Center Positive over Center Negative?
What makes the power supply current? because some products use 200ma or 500ma or 1250ma why does each piece of equipment or product use different currents?
How would a designer know how much "current" the power supply needs to be for the type of design or circuit?
walters is offline
Old 29th November 2005, 03:59 AM   (permalink)
1. I prefer to see negative on the outside, since it is more likely to short to ground and almost everything out there is negative ground which would not be harmed by this happening.
2. The actual current used is determined by the load, not the supply. The supply's rating is a maximum rating.
3. That's what designers do.
Oznog is offline
Old 29th November 2005, 04:05 AM   (permalink)
So you measure the Load of the power supply and thats how u get the current rating on the outside of the product is from the load?
But the Load is going to measure in ohms so how do u get the Current rating from that?
walters is offline
Old 29th November 2005, 04:26 AM   (permalink)
If i don't know what the voltage is going to be for the circuit or product how would i measure the load and get the current rating for the circuit to operate
Its like making a power supply voltage and current made for the circuit but how do designer know which voltages and current rates are for the circuit?
walters is offline
Old 29th November 2005, 04:52 AM   (permalink)
Well, generally the designer already knows what voltage the circuit needs to run at. Once he knows that, he has to calculate how much current the circuit will draw when supplied that voltage.
For example, when I built the circuit to power my calculator from a wall wart, I knew the whole system needed to operate on 6 Volts because that's what the calculator used. I also knew (from using my ammeter on the calc once) that the calculator could draw a max current of 125mA, so that told me the wall wart would need to handle at least 125mA. So I used a power supply rated 750mA. It was a little overkill, but it worked. To summarize that procedure:
(1) Knew the circuit needed to run off 6 Volts
(2) Supplied the circuit with 6 Volts and measured the current draw
(3) Choose a supply that could supply all the current I needed.
The most-hated young engineer in America.
* AVR Projects
* Robot War: TI
* About
DigiTan is offline
Old 29th November 2005, 05:05 AM   (permalink)
Thanks alot
So what u do is give the circuit the voltage once u have the voltage just put a ammeter to see the current draw when measuring and thats how u get the current rating?
The thing im worried about is when doing the measuring what if the current is to high it can damage the circuit
To measure current draw would mean putting the ammeter "before" the power supply or after the power supply by the load?
If i use my test bench power supply and put it to 6volts do i leave the current knob to ZERo so no current to being sent to the circuit and put the ammeter between the test bench power supply and the current to measure the current draw?
walters is offline
Old 29th November 2005, 07:35 AM   (permalink)
Hello,
Usually you should measure at the final load, at the circuit could be different points where you read other values not so interesting for you.
If you put the knob to zero then you limit the current supplying and you donīt have current through any load you connect to the power supply, what do you want to measure then there? It will be the same you donīt give any voltage to the circuit...
Regards from Mallorca.
Youīll never know enough...
2PAC Mafia is offline
Old 29th November 2005, 11:10 AM   (permalink)
thanks
So what do i do then? supply it with how much current to really know how the how much the current is drawing ?
walters is offline
Old 29th November 2005, 01:39 PM   (permalink)
Originally Posted by walters
The thing im worried about is when doing the measuring what if the current is to high it can damage the circuit?
Yes, because each component of a curcuit has maximum current ratings. If any one of the components has too much current, it will heat up, and possibly damage the entire circuit (probably over one component).
-=: The best low-priced components to troubleshoot with are the speaker and the LED :=-
mstechca is offline
Old 29th November 2005, 07:56 PM   (permalink)
Then how do i test to know the maximum current ratings without it heating up or damaging the circuit?
If i designed a circuit without a power supply but i know the voltage rated lets say +9 voltages my problem is knowing how much "Current" the power supply should be how do i find out how much current the circuit needs?
1.) Built the circuit without a power supply
2.) just know the voltage is +9 volts
3.) I do not know how to get the max. current draw or rating
4.) If i supply the circuit with some current and put a ammeter in series
it still won't tell me the max. current draw or rating because i just supply it with some current
walters is offline
Old 29th November 2005, 08:14 PM   (permalink)
When you design a circuit you select how much current each part uses by the design.
You can design a circuit to use extremely low current if you want. But it won't operate at high frequencies.
audioguru is offline
Old 29th November 2005, 08:32 PM   (permalink)
I still don't get how the transistors,resistors,capacitors current ratings can tell me how much the power supply current should be outputing like 400ma or 1250ma how would i know this ?
I think this has to do with Power and Wattage formulas maybe to find out the power supply current
walters is offline
Old 29th November 2005, 09:26 PM   (permalink)
Well this is how I do it (other might not).
I design the cct to work (using say generic OPAMP and such).
Once I get past this say concept design I move onto detailed design where I start specifying actual components.
ie I need a Schmitt inverter so I us a 74HC14 from Philips, I need an OPAMP and due to certain requirements (temp, slew,...) I choose a TLE2021.
I get to the resistors and check what voltage/current they will be seeing and make sure their footprint is sized for their power.
Once a detailed design is done I start by going over all datasheets and summing up all the MAXIMUM current (in worst-cases ie high temp).
I then have a rough current-level for the design.
Vero-board the design up and attach to a bench power-supply to get a more realistic current-drawn.
Now I do have a current-level being drawn I design/spec the DCC converter. Say I had a design that took 100mA from 28V on the bench. I could design it for 1A at 28V but the isolation trasformer and FET's would be bigger then they need to be and thus useless, so I spec and size everything for 150mA (or higher depending on the inrush but that is part of the detail testing)
That way my PSU is only as big as it needs to be
REmember a load will draw as much current as it needs. IF the PSU is capable of supplying more, doesn't mean the load will take it (it will in a fault condition, another reason for keeping PSU to their minimum current for protection)
Nothing is impossible.
Styx is offline
Old 29th November 2005, 09:41 PM   (permalink)
walters,
As was already mentioned the load determines the current, not the power supply. If you have no load connected to the power supply is uses zero current.
Once you connect a load circuit it draws as much current as it needs and the power supply provides it. When the supplied current exceeds the maximum it can it'll either blow a fuse or start to burn up.
Mike
upand_at_them is offline
Old 29th November 2005, 09:59 PM   (permalink)
thanks alot guys for the help and information
So if the Load measure 100K and the voltage is 9+ volts
i just use ohms law to find the current?
By load use mean Circuit Load? like measure the circuits resistance from ground to Positive+?
The hard part for me is where and how to find the load circuit resistance value?
walters is offline
