Old 26th November 2005, 09:55 AM   (permalink)
Default Transformer parameters.
I have got a 12-0-12 transformer that is rated for 5A.
But when I rectified, filtered, and added an LM338 regulator, I get not more than 3A current at 5v.
When I filter the ripple waves, I get a higher voltage ( I have not measured this with a true RMS meter.)
I calculate the transformer to be rated 60W.
But if I get about 18V (on non true RMS meter), Should I see it as 18x3~60W
SO does this means that the current rating of the transformer is an rms value?
Is Wattage a better way to describe the transformer ?
And How is VA different from Watts?
Bharath Bhushan Lohray.
M.Sc. Electronics.
lord loh. is offline
Old 26th November 2005, 09:59 AM   (permalink)
Default Re: Transformer parameters.
At that the LM338 would be dissipating something like 40W, and could well be thermal limiting - it's really too high a voltage transformer to feed a 5V linear regulator.
Nigel Goodwin is online now
Old 26th November 2005, 11:14 AM   (permalink)
it should be of 120W not 60W
we use VA along with powerfactor , for purely resistive loads VA and W are same.
akg is offline
Old 26th November 2005, 12:34 PM   (permalink)
That depends on the intent of the original designer of the transformer.
A 12-0-12 winding infers that the designer intended the transformer to be used with a bi-phase rectifier. ie two diodes, one from each 12v output, then take the +ve rectified output from the junction of the two diodes and the -ve output from the 0v centre tap on the transformer.
Each half of the secondary winding is only conducting half of the time, so you can use a thinner wire.
JimB is online now
Old 26th November 2005, 08:48 PM   (permalink)
So If I reduce my input voltage, could I use the linear regulator more efficiently? Say I use a halp wave rectifier instead of a full wave and filter it. Or use a 7.5-0-7.5 transformer...?
M.Sc. Electronics.
Old 26th November 2005, 09:08 PM   (permalink)
I would suggest a different transformer would be best, 7.5-0-7.5 might be OK, or try a 9-0-9.
Using a half wave rectifier wouldn't help anything, and you would need far more massive reservoir capacitors (I'm presuming you already have ayt least 10,000uF?).
Old 26th November 2005, 09:13 PM   (permalink)
:shock: :shock: :shock: :shock: :shock: :shock:
I have got a 2x2200uF=4400uf. And it drives two linear regulators. However, by a jumper setting, any one (or both :roll: ) of them can be disconnected.
10mF is a lot.... :shock: :shock: :shock:
M.Sc. Electronics.
Old 26th November 2005, 09:18 PM   (permalink)
(I'm presuming you already have at least 10,000uF?).
And 4400uF isn't much at all 8)
I'm also a little concerned about 'jumper settings'?, at these sorts of current short thick direct wires are what you should be looking for!.
« FSK | 8253 timer »
