| Your quest isn't over :lol: (or maybe it is) Anyways, I'm happy to inform some of you that the varactor trick has partially worked with my receiver. Here's why: The resistors I used for each bit from the 4-bit counter are as follows: 1.2K 2.7K 4.7K 6.8K I deliberately went over 1K for each value and tried to exponentially increase each resistor value based on what remaining resistance values I had on hand. When I used my computer (I wrote a Qbasic program) to calculate all possible resistances based on each counter state, I was happy to see that the voltage increments were small enough (about 6%) if the counter went through each bit combination in order. So that I believe is not too much of a percent. My supply voltage is switchable between 6 and 9V because I want to make my circuit work with a 9V battery for as long as possible. (please don't tell me to buy duracell or energizer, or some other premium brand battery) Audioguru made a transmitter circuit showing a diode and capacitor in series. I made it so that it appeared compatible with my receiver. Here were the results I got when I tried these values for diodes and the coupling capacitor: test #1 Diode: 1N4007 Capacitor: 150pF Additional capacitance added: None Result: No signal test #2 Diode: 1N914B Capacitor: 150pF Additional capacitance added: None Result: No signal test #3 Diode: 1N914B Capacitor: 22pF Additional capacitance added: None Result: No signal test #4 Diode: 1N914B Capacitor: 22pF Additional capacitance added: 4.7pF Result: Signal present only on two values (not bits). It makes me think that a diode can only produce a small capacitance. When I tested my circuit with just a standard LC circuit (no varicap add-on), and when C is 4.7pF, I got white noise in, which is good for now. I also added a 50% voltage divider. (two 680K resistors), because if I had all high bits or all low bits, I can't see how the circuit would work without them. The center of the divider as well as the output voltage from my counter is connected to the center of the varicap circuit. (between the reverse biased diode and capacitor). I begin to think that changing the diode to one compatible with higher frequencies might do the trick. What do you think? My objective is to get any signal in when I press the button. When I press it again, I want the signal (or at least the frequency) to change.
__________________ -=: The best low-priced components to troubleshoot with are the speaker and the LED :=- | |
| | (permalink) | ||||
Your digital to analog converter resistors at the outputs of the counter have values far too low. As explained in the other thread, the output resistance of the counter requires resistor values 10 times to 100 times higher for accuracy. The resistance of the varicap diode you are controlling is infinite since it is supposed to be reverse biased. Quote:
The capacitance of a reverse biased 1N914 diode is far too low for your circuit.
__________________ Uncle $crooge | |||||
| Here it is. The circuit in white is my regen detector that I will consistently use, because IT WORKS. The circuit in yellow is my add-on. I took audioguru's version of his varactor tuned transmitter and modified it slightly to suit my circuit, because my (LC tank) inductor is grounded. Like he said, I didn't use a limiting resistor between the voltage source and the junction between the capacitor and the diode. The bit #'s are the bits on the counter output. Bit 1 is the first bit (LSB?), the one that turns on first when I activate the clock on the counter. After pressing the button about 14 times (with a 4.7pF capacitor tied to the LC inductor which isn't shown), I got a signal. If I didn't use a divider network with the 680K resistors, then I would have a problem when all bits are on or off. Assume there were no 680K resistors: If they are all on, all resistors will be internally (according to the 74HC393) tied to VCC, and there would be no resistor tied to ground. If they are all off, all resistors will be internally (according to the 74HC393) tied to ground, and there would be no resistor tied to VCC. The goal is to provide a voltage, and my way of doing that is to always use a 2-resistor voltage divider. and the R-2R ladder is something I will pass up on, because I see no benefit with it.
| For those experimenting with ordinary diodes to be used as varicaps this site may be interesting: http://www.hanssummers.com/radio/varicap/ | |
| Hi Stubborn, 1) The varactor diode is supposed to be reverse biased. 2) Without a 100k isolating resistor, the output of the resistors of the counter were a 680 ohm RF short across the tuned circuit. 3) Where's your supply bypass cap? 4) Use a diode that has enough capacitance to do the job. 5) There isn't a requirement to waste up to 9mA and lose accuracy in very low value resistors from the counter. I won't comment on the rest of the circuit since you say it works. Try it like this:
| Althought diode 1N4007 has large enough capacitance ratio compared with 1N914 in this circuit it will be impossible to tune receiver through all FM band. I think that left pin of 150pF capacitor has to be connected to collector instead to emitter. | |
| Hi Bloki, If the 150pF cap was connected to the collector then the circuit would be a transmitter. MStechca is using his circuit as a receiver. Its 1mH tuning coil seems awfully large to tune the FM band.
| Collector coil is only 100nH and I do not agree the receiver will become a transmitter. To tune collector tank to 100MHz you need a total parallel capacitance of 25pF. Trick of those regenerative receivers is to set a working point that it does not oscillate continiously. Quenching oscillation at his peaks is driving it to oscillate. | |
| | (permalink) | ||
It is odd that it is a receiver without an antenna.
| I found a mistake in my upload. both inductors should be 0.1uH. and yes, I will up my resistance values at the counter. and I have a comment for Audioguru: Isn't your "corrected" varactor equivalent to LC in parallel? Mine should be equivalent to a capacitor connected between emitter and VCC. I am still deciding on the bypass capacitor. Experimentation so far is a good answer to me. and why isn't my diode reverse-biased when the cathode of my diode is connected to VCC?
| | (permalink) | |||||
With the tuning capacitance connected to VCC, then the circuit would work only if the battery is brand new so has a low internal resistance and the wires to the battery are very short so they have low inductance. With a supply bypass capacitor to make the RF potential of VCC and ground the same, then the tuning capacitance can be connected to ground or to VCC and even with a weak battery it will work the same. Quote:
With the diode connected to VCC and with the same supply voltage for the counter, the tuning is backwards. When the counter is reset then the resistors will have zero voltage output and the capacitance of the diode is at its minimum and the RF frequency is at its highest. With the diode connected to ground like I show it, when the counter is reset then the radio will tune to its lowest frequency. Then clocking will increase the frequency. Isn't that what you want? You are using an ordinary diode to replace a varactor which has a much wider tuning range. The tuning range with an ordinary diode isn't enough, unless you increase the supply voltage of the counter for the diode to have a wider tuning range. With the diode connected to ground like I show it, you can increase the supply voltage of the counter if you use a CD4024 counter with its much higher VCC rating. :lol:
__________________ Uncle $crooge | ||||||
| | (permalink) | ||||
Notice how I called it AC-VCC and AC-GND? I did that because the VCC coming from a battery is NOT the same as battery's ground. but in AC, things change. Quote:
btw, my circuit I am modifying is on PCB. Quote:
If I were to replace the diode with a diode with a higher tuning range, should I go for the 1N5221 or some other diode? I don't want to blow my money on a varicap and find out later that it is useless. Also, my supply voltage must be switchable between 6 and 9V, because I want my receiver to work on an almost dead battery. and so far, my receiver works from 9V to 6V. The only thing I might have to do is alter the jumper setting in my circuit. so your idea of higher VCC isn't going to go well with me or my circuit.
__________________ -=: The best low-priced components to troubleshoot with are the speaker and the LED :=- | |||||
| | (permalink) | |||||
Use an additional 100uF to 1000uF to bypass audio frequencies. Quote:
Low voltage zener diodes are lousy for anything. With a reverse voltage of only 2.6V, it typically leaks 5mA. Its capacitance is far too high and its range isn't enough for your application. You should use a proper varactor diode for tuning. If you can't afford mail-order then go to the dollar store and buy a "scanning FM radio" for $1.00. It is a lousy radio but it comes with stereo earphones (the radio is mono) and two cheap AAA battery cells. Its varactor diode tunes the entire FM band with less than 3V. I didn't look but its parts are probably tiny surface-mount. Quote:
Reminds me of the UK TV show "Blue Peter", where they crush biscuits up to use to make more biscuits? - strange idea?. | ||
