Old 16th November 2005, 07:00 PM   (permalink)
Default Using pc as a signal generator - input impedance query
Was gonna use my laptop soundcard output as a signal generator, just wondering if its okay to do, and what kind of input impedance should i use on my circuitry.
Megamox
Megamox is offline
Old 16th November 2005, 08:25 PM   (permalink)
Just had a thought, the earphones that you connect to an audio output are about 8-16 ohms. So i guess this is the nominal input impedance i should use for maximum power transfer right.
Megamox is offline
Old 16th November 2005, 08:37 PM   (permalink)
You don't want maximum POWER transfer, you want to feed the lowish impedance output of the sound card to a higher impedance to give maximum SIGNAL transfer. The earphones you connect are most probably higher than 8-16 ohms, older ISA sound cards could feed normal speakers, later (ATX onwards) sound cards require amplified speakers, they are far too quiet with passive speakers.
I suggest you are EXTREMELY careful, it would be a shame to destroy your laptop?.
Old 16th November 2005, 08:46 PM   (permalink)
Would be indeed, not something i can afford to do!
Megamox is offline
Old 17th November 2005, 02:39 AM   (permalink)
Lemme make sure I've got this impedance matching stuff down:
MAX POWER TRANSFER:
Match input and output. Transfer is 50% maximum.
MAX SIGNAL TRANSFER:
Low impedance -> High impedance. Is this close? Anything else I should know?
The most-hated young engineer in America.
* AVR Projects
* Robot War: TI
* About
DigiTan is offline
Old 17th November 2005, 05:56 AM   (permalink)
You should know that the low impedance of the sound card's output has enough power to destroy itself or a load. If the load is an electronic circuit and the output level from the sound card is too high then something will probably be destroyed.
audioguru is offline
