Originally Posted by firebird Hi there. I am relatively new to electronics and I have a question. Suppose you want to connect two circuits togheter, such as two op-amp circuits for instance. So, would it be better to work with matched impedances or would it be better if the first circuit has a very low output impedance and the last circuit has a very high input impedance ?
Thanks for your help. |
For maximum signal transfer you feed a low impedance in to a high impedance, you don't need VERY low, and VERY high - ten times the impedance is usually fine.
Matching impedances gives maximum POWER transfer, but by definition attenuates the signal by 50%.
You can work it out quite simply by ohms law, it's simply an attenuator (or potential divider).
