Old 16th November 2005, 01:32 PM   (permalink)
Ahhh i see. Yeah that makes sense.
Megamox is offline
Old 16th November 2005, 06:27 PM   (permalink)
hi
thoday i taken one of my lasers apart, and there was a lenz and a micro led.. the amazing part is that the led bright is too low without the lenzand it can not travel even 30cm so i tried the lenz with a normal Light-emitting Diode(led) but the lenz could not focouss it :?:
does anyone know if the laser pointer distance(more than 700m) is because of its lenz ONLY? if so then i should be able to use from a lamp or led instead of the laser lamp?
what is the story??? :idea:
epilot is offline
Old 16th November 2005, 06:31 PM   (permalink)
It's not just an LED, it's a Laser Diode, these produce coherent light, which the lens can then focus - a normal LED (or lamp) produces in-coherent light.
Old 16th November 2005, 06:39 PM   (permalink)
its monochromatic and in phase, if i remember right.
Megamox is offline
Old 16th November 2005, 06:59 PM   (permalink)
i can not understand you!
what "coherent light" means here?
do you think a common led can not be so focused to go very much destance?...
epilot is offline
Old 16th November 2005, 07:20 PM   (permalink)
Do a Google search on "coherent light".
Ron
Roff is offline
Old 16th November 2005, 07:49 PM   (permalink)
"Coherent" means there is only 1 principle wavelength produced, thanks to the quantum properties of the junction material. That's true for all LEDs exept for white, white are blue LEDs with a yellow-emitting phosphor.
The most-hated young engineer in America.
* AVR Projects
* Robot War: TI
* About
DigiTan is offline
Old 16th November 2005, 08:26 PM   (permalink)
This is why I told him to do a Google search.
While it's true that LEDs produce only one principle wavelength, that is not the definition of coherence. Coherence means all photons are in phase. Lasers produce coherent light, LEDs don't.
Ron
Roff is offline
Old 16th November 2005, 08:37 PM   (permalink)
I wonder if the "lens" of a laser diode is part of its internal reflecting mechanism that causes it to oscillate only at the single frequency where all waves are in-phase.
audioguru is offline
Old 16th November 2005, 09:12 PM   (permalink)
I don't think so. Here is a good article that explains the semiconductor laser structure.
I actually don't know squat about laser diodes.
Ron
Roff is offline
Old 19th November 2005, 10:32 AM   (permalink)
If you connect a variable power supply to a cheap red laser pointer, and gradually increase the voltage from 3 volts, the output power will increase to a peak, then fall as voltage is increased further. It is quite safe from the laser's point of view to run at this peak, but watch the power dissipation in the series resistor. So far, best results are 7mW from a <1mW laser pointer.
While on the subject, if you look at a spot of laser light, you will see a grainy pattern, which will be in focus. If you put a lens over your eye, so that you can't see anything else, the grainy pattern will still be in focus. Only coherent light will do this.
spuffock is offline
