Old 13th November 2005, 02:32 PM   (permalink)
Default Components keep falling off !!
Usually i use a bit of bluetack to hold components in place, so that when i turn the boards over to solder them they stay in place. I know if i could hold them all at once, i could solder the whole board quicker!! But if i put too many on at a time, they either all bend, or fall off, such a hassle. How do you guys do it?
Megamox
Megamox is offline
Old 13th November 2005, 02:37 PM   (permalink)
I use green masking tape. When the parts cool, it doesn't leave its adhesive behind like ordinary masking tape.
audioguru is offline
One at a time?
Time is nature\'s way of keeping everything from happening at once.
http://membres.lycos.fr/jrainville/
Joel Rainville is offline
Old 13th November 2005, 02:57 PM   (permalink)
Aspestos finger-tips.
After time you can hold a leaded resistor in place and solder it down (for trough-hole) without you even feeling it
remember you dont need to do a full,good solder for the first leg. Just a kind-of tacking solder to allow you then to do a propper solder on the other leg and then finish the first
Nothing is impossible.
Styx is offline
Old 13th November 2005, 03:19 PM   (permalink)
I Put Most or All the Resistors on the board first. Than I place a Piece of Thick Felt (or Cardboard) over them. Now turn the board Over and they all stay in place as you lay it down.
And The Soft Felt Protects them from Damage.
(Actually I use a Piece of Ozite, Indoor/Outdoor Carpet)
Repeat next with Smaller Caps, Than IC Sockets and lastly Larger Parts.
Quite Often I just Solder ONE Wire of Each Part. Than Flip Board to check Alignment, Before Continuing to Solder the other Lead or Leads.
Works Very Well.
I No Longer accept Private Messages on here.
All Emails to me Must Contain the Word \"Electronic\" in the \"Subject Line\"
or they go Directly to my Junk Mail Folder.
Email me at: chemelec@hotmail.com
Website: http://www3.telus.net/chemelec
chemelec is offline
Old 13th November 2005, 03:22 PM   (permalink)
even better is to use as much as possible SMD components. you dont need to hold them from the other side
Need Help?
Press F1
If that doesn\'t help you, ask me... I might know better.
bloody-orc is offline
Old 13th November 2005, 03:28 PM   (permalink)
It all depends on the components, for resistors and capacitors I usually fit them a few at a time, and bend the leads over slightly to hold them in place. For something like an IC socket I'll fit them one at a time, and hold them in place with a finger while I solder them.
I've NEVER considered using blue tack or tape, or any method of holding them in place - there doesn't seem any point, or advantage?.
Old 13th November 2005, 03:47 PM   (permalink)
Maybe im not dexterous enough but it seems that i can do better joints when im only holding the iron and solder, anything else and the iron is shaking all over the place! before you know it something slips, while trying to catch it you end up soldering an eyebrow :P
Megamox
Megamox is offline
Old 13th November 2005, 04:32 PM   (permalink)
I have a little PCB work frame (well actually it's a bit big & bulky but anyway...) which has a sponge lid. You can position the frame a bit like a graphic drawing board. You put all your components in place, then clip in the circuit board with the adjustable sliders and tighten the sponge pad onto the back. It cost around £120 I think from R.S, but I managed to get mine for £30 off eBay Bit of an expensive one I suppose, but when I decide to do something (i.e. build a work bench) I do it properly.... :lol:
Mike
roboticmisinfo is offline
Old 13th November 2005, 06:09 PM   (permalink)
I solder in order of lowest profile, that is, the lowest profile smd parts, then 1/8th watt through hole resistors, then the machined pin IC sockets, on up to the highest profile components... Insert a couple parts, lay a pad of paper over the components, flip over the pad and pcb, place gentle pressure on the pcb while using both hands for soldering... Works great...
Good luck... Regards, Mike
Mike, K8LH is offline
Old 13th November 2005, 06:26 PM   (permalink)
I also solder items having the same height at the same time. I stretch my green masking tape fairly tight over them to hold them in place while I turn the pcb over. Then my workbench holds them as I solder them.
Duh! When I remove the tape and there is a part on it then I know that I missed soldering it. :lol:
Old 13th November 2005, 07:12 PM   (permalink)
Default Re: Components keep falling off !!
Megamox
I never had a problem with parts falling off of the board.
Why don't you just bend the leads after putting them through the holes?
It's the 90 degree bends, as well as the width of the component that holds it in place. It's like putting a water tube around a fat (not-so-skinny) kid :lol:
Yes, the leads MUST bend in this case, but it is to your advantage.
After all, the circuit you are building is "supposed" to work, or you wouldn't be at that stage.
-=: The best low-priced components to troubleshoot with are the speaker and the LED :=-
mstechca is offline
Old 13th November 2005, 07:32 PM   (permalink)
Never actually thought of bending the leads, ill try that, thanks.
Megamox
Megamox is offline
Old 13th November 2005, 07:35 PM   (permalink)
yes, I always put my components through the holes, and bend the leads flush with the solder side of the board. Holds them in quite nicely.
windozeuser is offline
Old 13th November 2005, 07:48 PM   (permalink)
I suppose its a good idea to bend them at different angles so you dont end up soldering one lead to another lead.
Megamox is offline
