Short leads are better, unless in very rare cases, you need a track that has extremely low resistance and inductance. That should only happen if you are making a UHF or a radio device with an extremely high frequency. If you have fine tools, try to have the lead length to only 2mm + the width of the board, so that the chances of one lead running into the next is slim.
__________________ -=: The best low-priced components to troubleshoot with are the speaker and the LED :=- | ||
| Well, yes you bend them solder them then snip them. That's how I always do it. | |
| That's what I do too. Is the green tape audo referred to also called 'painters tape' in some shops? | |
| Yeah, the green tape is for painters 'cause its adhesive is mild and doesn't pull paint off walls. It comes in different qualities. I have one that melts all over the place, then is way too sticky when it has cooled.
You: 1. snip (cut to minimal length, but not too short) 2. insert (insert it into the PCB) 3. bend (at 90 degrees) 4. solder EDIT: I forgot to mention that TAPE is not a recommended item for holding components, especially when heat is close to them. Tape is not designed for hot environments.
| I do as others do, which is soldering from the lowest profile upwards. In addition, I find a sponge quite useful in such situations. | |
| I actually use ordinary sticky tape, and I cut the leads very short before soldering. I put a lot of parts on at once, but do wires and annoying bits afterwards. Once though, the tape melted in a fine layer onto a XLR plug I was soldering, and that actually stopped it from working until I noticed it and sanded it off :lol:
__________________ Angry!? I'm absolutely electrolytic! Will have to make do with myspace now I guess... | |
