Old 11th November 2005, 05:33 AM   (permalink)
Default Single Stage coil gun
Hey, I currently got into the mood to build a coil gun :twisted:. I've been thinking of buying some photo flash capacitors about 15, 150uF caps. Wiring them in parallel, and using the charger circuit from a throw-away camera. The barrel will probably be a disassembled pen with magnet wire wrapped around it.
I was thinking about using these capacitors:
http://www.rubycon.co.jp/en/catalog/...minum/e_FK.pdf
Please if you know of better ones, please post.
Some questions I have are, where can I buy photo capacitors cheaply? How do I calculate the amount of energy the capacitors will release, and be sure the wire can handle the current? Also, what can I build to charge the capacitors effciently.
I'm open to suggestions, please share your experiences and ideas.
Thanks!
Note: I only want to build a Single Stage coil gun, I will be happy if it can accelerate a projectile about 35 feet
windozeuser is offline
Old 11th November 2005, 06:30 AM   (permalink)
amazing1.com sells a very similar capacitor for $12.95 each. I've managed to get this type of capacitor for as low as $10 each in the surplus market, but this was a walk-in store and is a pretty tough price to beat. I've also gotten discarded cameras from Walgreens and CVS pharmacy. If they ask why, just say you want the capacitor--you'll get a free battery too.
The total energy storage is calculated by:
E = 0.5*(C*Vē) [ in Joules]
...this is still misleading because your capacitor won't be able to discharge all that energy before the projectile leaves the barrel. Typical homemade coilguns only convert about 1% or 2% of their energy bank into motion; and Los Alamos was up to the 20%'s--probably thanks to superconductors.
One device you might like is the Marx Generator. It charges your capacitors in parallel and discharges them in series. That (tends to) drive charge through the coil faster, resulting in a more violent launch.
Anyway, there are alot of other factors to throw in like coil saturation (heating), projectile saturation, switching, etc. My best advice is to start things by designing and testing the coil, then choosing the projectile. There's a listing of 15 Real Coilguns on the link; a few are even uC-controlled. 8)
The most-hated young engineer in America.
* AVR Projects
* Robot War: TI
* About
DigiTan is offline
Old 11th November 2005, 05:19 PM   (permalink)
I think you need a real capacitor charger. The little thing in a camera will melt before it takes a very long time to charge all your paralleled caps.
audioguru is offline
Old 11th November 2005, 05:47 PM   (permalink)
Hello windozeuser,
Insead of spending a lot of cash for some photoflash caps, you should just got to a few places and get them for free like Digitan said, I did this and got about 20 from walmart in one trip. (Don't get shocked when taking them out of the cameras, some are charged when you get them (PAINFUL)!
You could probably make a simple circuit to charge the caps faster than the camera circuit does. To chareg a 10 cap bank it takes more than a minute!. A 555IC, the transformers in the cameras and a few resistors should charge them up very quickly.
George L.
George L. is offline
Old 11th November 2005, 06:20 PM   (permalink)
windozeuser
Have you tred eBay, lately i've seen some pretty powerfull caps on ebay , they are used for car audio sound systems..
two or three of the single Farad versions in parallel , could probably start your car, or shoot a neo magnet through the wall :twisted: ..
williB is offline
Old 11th November 2005, 07:12 PM   (permalink)
You need an much higer voltage than 12V.
I found out 50V not enugh.So i went to 100V.Most coilguns work from 400 to 800V.
Il give you shocking experience.
Someone Electro is offline
Old 11th November 2005, 07:19 PM   (permalink)
Somebody on one of these posts is claiming a coil current of 500A through his little wires with alligator clips!
I think the little wire would jump farther than the projectile if it had as much as 10A through it.
Old 11th November 2005, 09:37 PM   (permalink)
Yes, there's some very imaginative values about! :lol:
Old 12th November 2005, 12:07 AM   (permalink)
Hey thanks for all your replies
Originally Posted by George L.
Hello windozeuser,
I went to wallmart today and asked the lady in the photo department "Do you resell or give away throw-away cameras you develop" Shes like "NO, We recycle our throw-away cameras, it's not in my policy to give you any"
How did you guys get them?
Btw, I bought 40 feet of 22 gauge magnet wire from radioShack. Is there a guide on how to construct coils around say a certain diameter tubing. Then find out the strength of the flux lines inside the tubing.
Thanks a lot
Wouldn't the entire current just be a huge spike that only last a couple of mS's? Would that be enough to heat the coils up and cause them to short out and arc? I guess it would depend on the inductance of the coil with and without the ferrous projectile, and also the resistance of the coil?
But as I see the power value of a theoretical 400V setup...
P= 500A * 400V = 200,000 Watts o.o
How do you calculate the current capacity of magnet wire?
Originally Posted by williB
windozeuser
Or knock you dead cold in less than a second heh heh, but seriously thanks for the advice I'm gonna search ebay right now
Old 12th November 2005, 12:26 AM   (permalink)
The high-current pulse is so quick that only little wires with alligator clips would get hot and maybe melt. I think the little wires are 22 guage like the wimpy wire you bought.
If you made the circuit into a rapid fire machine gun then lotsa stuff would get hot. :lol:
Old 12th November 2005, 12:28 AM   (permalink)
Oh yeah, forget about the low voltage caps for car amps. You need high voltage to produce enough current in the coil.
Old 12th November 2005, 12:54 AM   (permalink)
What do you think about buying say uninsulated 14 or 12 gauge copper wire, then coating it in my own enamel? Instead of using that 22 gauge floss ;P
I would think it would open up a wide range of potential failure, and also what would I use to coat the wires if I can't obtain enamel?
Old 12th November 2005, 01:36 AM   (permalink)
Basically, I waltzed into Walgreens, and asked what they did with cameras they were throwing out. The photo guy asked if I had lost film, and just said I needed the transformer--and they pulled it out of the bin. If they ask questions, make it clear you're not interested in film, you're just a student/hobbyist/professional in need of the components.
Like the others suggested, I wouldn't recommend using the camera's supply. It uses a cheap load-dependent oscillator for DC-to-DC, and even cheaper step-up transformers. A high-end gun would also use NiCad, Nickel-Metal, or --in the extreme-- LiPoly batteries for a source.
The single-stage designs seem of favor the heavy guages.
* AVR Projects
* Robot War: TI
* About
DigiTan is offline
Old 12th November 2005, 02:09 AM   (permalink)
What do you think about buying say uninsulated 14 or 12 gauge copper wire, then coating it in my own enamel? Instead of using that 22 gauge floss?
RadioShack isn't the only electronics parts supplier. Digikey and Newarkinone have thousands of enamel-coated wire sizes and lengths and if you place an order before 8:00PM, it is delivered to you the next morning at much less cost than RadioShack.
22 guage wire will hug the coil former closer and would be fine with a few hundreds of volts supply for the pulse.
Old 12th November 2005, 03:21 AM   (permalink)
I'm planning on ordering magnet (enameled) wire from Electronic Goldmine. They have really good prices if you need a couple pounds or more of one size wire.
Ron
Roff is offline
