+ Reply to Thread
Results 1 to 7 of 7
Thread: Johnson counter
  1. #1
    Ybody Newbie
    Join Date
    Jun 2003
    Posts
    2
    Default Johnson counter
    There is probably an extremely easy way of doing this that I am missing.
    Using a 4017, I am able to verify my counting works by breadboarding some LEDs to the respective outputs.
    I have a stopwatch that requires a low to start and another low to stop. Normal stopwatch, so if the low never goes high, it will still be timing. As it stands right now, once output 0 goes from high to low, the timing starts. It cycles through all the other LEDs and the stopwatch continues running. Go back through the cycle, LED 0 lights up and as it goes out, the timer stops timing. Say I want it to start on the dropout of LED 0 and stop on the dropout of LED 8...
    |   4017   |
    |__________|
    0 1 2    8 9
    R1       R1
    LED      LED
    |_*____*_|
         SW
       Ground
    Should I just pop 2 diodes in where the "*"s are or is there a better way of doing this? SW is the stopwatch connection to the start/stop button. This is my first shot at this, and after about a day and a half of 4017 and quad comparitor searching, mind mind is pretty much fried. TIA
  2. #2
    Super Moderator kinjalgp Newbie
    Join Date
    Oct 2002
    Location
    INDIA/USA
    Posts
    1,855
    Since LED is also a diode, you don't require any additional diodes.
  3. #3
    Super Moderator mechie Good mechie Good
    Join Date
    Sep 2002
    Location
    Lincolnshire, England
    Posts
    592
    Edited for stupid mistake ops:
    The best way of dealing with this (depending on what you want) is...
    Use the LEDs as the 'OR' gate - move the resistor to further down the circuit
    -- still loses about 2v across the LEDs
    Better to use signal diodes (1N914 or similar) as the 'OR' gate then the LEDs can be omitted if required
    -- only loses about 0.7v across diodes
    I need a memory upgrade ...
    My head is full !
  4. #4
    Join Date
    Oct 2002
    Location
    INDIA/USA
    Posts
    1,855
    Use the LEDs as the 'AND' gate
    Two diodes, with their cathodes shorted will form "OR" gate not "AND" gate. The output will be logic 1 even if anode of any one diode is at logic 1. And thats the truth table of "OR" gate.
  5. #5
    Sebi Newbie
    Join Date
    Jan 2003
    Location
    Hungary
    Posts
    1,717
    The two diodes can work as AND gate with reverse polarity, and pull-up resistor in common anode....
  6. #6
    Join Date
    Sep 2002
    Location
    Posts
    592
    Default Dho !
    Sorry guys --- you got me :!:
    The diagram is correct
    My waffle is wrong ops:
    Not thinking before I rattle my keyboard -- I meant 'OR' gate, honest :roll:
    ....................Original post corrected !
    My head is full !
  7. #7
    Join Date
    Oct 2002
    Location
    INDIA/USA
    Posts
    1,855
    Quote Originally Posted by Sebi
    Yeah ,thats true!
+ Reply to Thread
Tags for this Thread
