| In my receiver, I am at the moment, using a CMOS 4024 IC. After research, I think that switching to a counter in a 74HCT IC is better, provided that I change my voltage. I don't know the best class to use. What I have learned from experience is that the 74LS series tend to burn out easier. so can someone list me in order of maximum voltage, followed by maximum speed which IC family I should use? I'm willing to buy another counter IC. I would like the receiver to run on 9V as well, so any IC that works with 9V will be great.
__________________ -=: The best low-priced components to troubleshoot with are the speaker and the LED :=- | |
__________________ Beginner's Guide to Microcontrollers | |
| I thought it was a transmitter that you were trying to tune with the counter. The problem of using a counter in your circuit will continue with any other logic family. A counter's outputs have logic level voltage changes, not switches. When a counter output is high, its "tuning capacitor" is connected across your inductor, if the wires are short enough. When the same counter output is low, then its tuning capacitor is still across your inductor because the supply has a low impedance filter cap to ground. Therefore the capacitance across the inductor doesn't change when the counter's outputs change. Threrefore the tuning doesn't change.
| All chips beginning with 74 have 5V supply voltage except 74HC series which can be supplied with 6V. CMOS 4000 series can be supplied with maximum of 15V. I think you know it. Once I met high voltage TTL chips that had 15V supply but it was some 30 years ago. | |
| 74HC series ICs are guaranteed to work with a supply voltage as low as 2.0V so I used them in my 3V Ultra-bright Chaser project where the battery voltage drops to 2V over its long life.
| huh... :lol: | |
| | (permalink) | |||
Here's my theory Quote:
__________________ -=: The best low-priced components to troubleshoot with are the speaker and the LED :=- | ||||
| The 74Cxxx series, like the 4000-series, can be operated as high as 15v on the power supply rails. TTL for 15v power supply? I don't think so. The "high voltage" operation you may be thinking of was for display drivers and open-collector logic where you could use higher voltages, sometimes even driving Nixie tubes in some cases. 74LS "burns out" so easily? TTL and ECL is probably the most durable of all the logic families. You want easy to destroy? Try using the old 4000A series vs. the 4000B series. Wow. Look at it cross-eyed and ESD zapped it because it had no internal protection. The BEST logic family? By far, it's 74xxx, 74Lxxx, 74Sxxx, 74LSxxx and 74Hxxx. Why? Because it's what I have the most of. Probably on the order of 2000-4000 chips available. So, it's the best because I can build nearly anything for next to zero cost. I don't have to run out and buy the latest PIC or µP or odd-ball logic family to build a circuit. Yes, the digital stopwatch, digital clock, frequency counter or other logic circuit I build will require a lot more chips, use more power, take up more space, be more difficult to build, etc., but it won't likely cost me a dime for parts. And I'll also know the circuitry a lot more intimately that I would with an LSI equivalent. Dean
| | (permalink) | |||
We wish you would understand this.
__________________ Uncle $crooge | ||||
For speed to power dessipation LS is the optimum. Often speed and (power dessipation and voltage levels) are inversely proportional. The datasheet of CMOS ICs specify the maximum switching speed with a Vcc specification. If the Vcc is kept at maximum allowed voltage, the speed the max. And the power desipation is specified at minimum voltage. :?
__________________ Bharath Bhushan Lohray. M.Sc. Electronics. | ||
Audioguru is right. one of the first thing they teach you in dealing with AC signal analysis is that DC VOLTAGE SOURCES ARE AC GROUNDS! when you look at a circuit in terms of AC signals (like radio signals), VCC and ground are considered the same point, because VCC is a DC voltage, and has no AC content. so literally, take your little diagram, cross out VCC, and draw a ground symbol there, and maybe then you can see why the capacitor is in parallel with the inductor in both cases!
__________________ EEgeek.net | ||
| | (permalink) | ||
To me, AC means alternating current. where the two rails consistantly change polarity. The capacitor is useful for holding the voltage, and I think it is what is actually causing VCC and ground to be equal.
| | (permalink) | |||
| | (permalink) | ||||
I didn't say I was going to do it. I'm sure an electronics novice knows not to do that, right? Quote:
__________________ -=: The best low-priced components to troubleshoot with are the speaker and the LED :=- | |||||
