| Hi, I'm doing a dsp project to rebuild a coded signal so I need to have access(just read) from a memory that contain the signal's data.I 'm thinking to use a flash memory with usb interface or somthing cheap enough with long work age but i have no idea how can i read from a flash memory.
__________________ Upper than heaven sina | |
| with proper drivers installed..the OS will consider the flashdrive as a removable drive..and u can access the file system as normal.. is that u want? | |
| hi, sorry i think i should explain more about my poroject. i want to rebuil a system with a cpu ro microcontroler(not a computer) so i need to do the hardwere and softwere by myself
| There may be no need for USB. Many cheap flash RAM ICs are made with I2C and SPI interfaces which are very easy to access with a microcontroller. USB is more difficult to implement, usually a special uC with hardware USB is needed. Most types of flash disk cards have a SPI interface in addition to the normal card interface. This is easy to access. A uC usually has some amount of flash RAM, often 256-1k bytes. Most PICs can also write data into the code space on a block-by-block basis, but the code space is not extremely large either. If you're building a single board computer, the USB interface may be easier.
