| | #16 | |
The way your choke is shown, implies a normal mode choke. A common mode choke would filter only signals common to both your supply rail & ground rail & would be shown with a different symbol. I dont think you need concern yourself with it based on the example you are experimenting with. | ||
| | #17 |
In this copy of your scope shot (below), if you think the aberrations that I have circled are noise - they're not. They are quantization artifacts of your instrument if this is from an oscilloscope, or from your computer or monitor if this is a simulation (which I think it is). As Optikon pointed out, thermal noise in an inductor is the least of your worries when you are making a power supply. In my 40+ years as an engineer, I have never heard the subject mentioned, in any circuit application. | |
| | #18 |
okay.. thank you very much.. :) so, the 1/f noise is also called as excess noise? quote: What do you mean why use in switching mode design? i am sorry, in the previous message, i mean in switching mode power supply design (SMPS) .. can you please give me a simple schematic example of common mode choke filter..? what is the meaning of quantization artifacts? i simulate the circuit with a software (multisim) :) i just want to know, because i heard from my lecturer, he said that inductor is the source of noise.. so i try to simulate it in the simulation software to find out which one work better as a filter, and i see the abberation if i use inductor, so i think it's the noise.. i am sorry... hehe.. :) | |
| | #19 | |
Here are two plots of the exact same sine wave, plotted on different scales. Notice the increased visibility of steps in the bottom plot. The voltage source being plotted has no steps. I simulated this on Linear Technology's SwitcherCAD III, but the results will look the same on almost any simulator. The vertical drafting resolution is not very good. The waveshape gets quantized (digitized) by the limits of the plotting software and, to a lesser extent I think, the hardware (the raster on your monitor). If you were to zoom in on that noisy portion of your simulation (before you save it as a graphic), the noise would go away. | ||
| | #20 | |
http://www.butlerwinding.com/inductors/common_mode.html Dont confuse this with the other sources of intrinsic noise talked about earlier. I doubt your instructor believes that inductors can _source_ noise. Where would the energy come from? Your circuit causes noise! Energy source is from your 60Hz generator. Having both and L and C in your circuit is better (noise-wise) than having just a single L or a single C. You have a two pole filter instead of one pole. | ||
| | #21 |
Perhaps it would be an idea to tell us EXACTLY what you are trying to do?, if it's simply that you're playing with a simulator, then you're probably wasting everyones time (including your own). However, if you're trying to design a 1950's (or 30's or 40's) valve power supply, then you're also wasting your time with such questions about noise. | |
| | #22 |
okay thank you very much ![]() i am sorry for wasted everyones time i just want to know is it right that the inductor source noise, and i try to simulate a circuit with the inductor, so, i choose a simple power supply circuit for compare is it true that inductor is the source of noise.. okay.. thank you all | |
| | #23 | |
I fyou want to study noise of individual components, you will need to setup a noise simulation with proper modelling. The power supply is a poor choice because it overcomplicates things. All you need for a simple noise simulation is a generator and a component. If you study up on noise theory, you will find that pure reactances do not exhibit intrinsic noise sources, so why would you think a simulation would show one? If the sim did, I would believe it to be incorrect. | ||
| | #24 |
okay opticon.. thank you.. | |
| choke, filter |
