Old 2nd November 2005, 02:28 PM   (permalink)
Default capacitance
I was looking at the website for my counter:
http://www.fairchildsemi.com/pf/CD/CD4024BC.html
The datasheet states that each input pin has a capacitance of 5 to 7.5pF.
Is it possible that I can some how makee each input pin have no capacitance?
I didn't realize this when I was making my digital station changer.
I knew something was going on...
-=: The best low-priced components to troubleshoot with are the speaker and the LED :=-
mstechca is offline
Old 2nd November 2005, 02:36 PM   (permalink)
No it is Not Possible.
I No Longer accept Private Messages on here.
All Emails to me Must Contain the Word \"Electronic\" in the \"Subject Line\"
or they go Directly to my Junk Mail Folder.
Email me at: chemelec@hotmail.com
Website: http://www3.telus.net/chemelec
chemelec is offline
Old 2nd November 2005, 03:38 PM   (permalink)
nope not posible.
but 5 pF is wery litle capacitance
Il give you shocking experience.
Someone Electro is online now
Old 2nd November 2005, 05:22 PM   (permalink)
MStechca,
The only input pin you were using was its Clock input which was connected to a switch, not the frequency-determining parts.
Your frequency-selection capacitors were connected to its outputs, which are shorted to either the positive supply for a logic high (which is decoupled to ground) or to ground for a logic low, so the capacitors didn't do anything. The counter wasn't switching the capacitors in and out!
Since your counter was at a distance from the tuning coil, the connecting wires had capacitance between them and to ground and served as an antenna.
Why don't you tune your transmitter with a reverse-biased varactor (vari-cap) diode? As I showed, you don't have to buy a special one, any reverse-biased diode or transistor junction will work. It can be connected directly to the tuning coil with a coupling capacitor with very short wires and its capacitance is changed by changing its voltage, with a resistive ladder connected to the outputs of your counter if you want. The counter and resistive ladder perform as a digital-to-analog converter. The varactor diode is reverse-biased so draws no current and its capacitance can be isolated from the resistive ladder with a high-value series resistor.
You can even modulate the varactor diode's voltage with the output of a preamp for the transmitter to have FM.
audioguru is offline
Old 2nd November 2005, 07:03 PM   (permalink)
Originally Posted by audioguru
<snip> any reverse-biased diode or transistor junction will work. <snip>
With the restriction that, if you want to tune the entire FM band, the absolute minimum capacitance tuning ratio must be
(108/88)^2 ≈ 1.5
This goes up when you consider device and stray (wiring) capacitance.
Also, we need to consider that the tank voltage modulates the capacitance. For high-level oscillations like we see on Mstecha's transmitter, this creates even harmonic distortion, and possibly forward-biases the diode on a portion of each cycle, both of which are, I think, undesirable. That's why I pointed him (in another thread) to Harry's Homebrew Pages, which has a transmitter that overcomes these problems.
Ron
Roff is offline
Old 2nd November 2005, 08:41 PM   (permalink)
Good points, Ron. :lol:
I remember that a dual varactor cancels 2nd harmonic distortion somehow.
Old 2nd November 2005, 09:35 PM   (permalink)
Yeah, I remember playing with that years ago. I think you still have the problem of potentially forward biasing the diode on signal peaks. In order to get good tuning range from a varactor, you need to operate from a bias voltage as low as 1 or 2 volts. If the AC swing on your tank is 4V p-p or more, that can be a problem. You can use a small-valued series cap and a large varactor, which tends to attenuate the AC, but then you need a varactor with a bigger tuning ratio. I believe varactors are easier to use in receivers, where amplitudes can be low, or in transmitters which have a low-level oscillator followed by a power amplifier stage, such as Harry Lythall's.
Ron
Roff is offline
