| Hi Everybody, Can someone please explain the difference between an octal inverter and a hex inverter? Would I use either of these to "invert" the positive and GND to motor controller if I wanted the motor to go forward and reverse? Thanks everyone!! | |
| An inverter is probably the simplest logic device you will come across. It has one input, and one output. If you put in a logical HIGH signal, you get a logical LOW at the output, and if you put in a logical LOW, you get a logical HIGH out of it. A "hex" inverter is simply 6 inverters in one chip. An "octal" inverter has 8 inverters in one chip. | |
| So how can I create a step motor controller which will allow the motor to go forwards and backwards? Wouldn't I need something to "invert" the current? Thanks!! | |
| You might find the L293D more suitable for your project. It can drive a small motor up/down. HTH | |
| Improving Power inverter | Hussein Kkaanya | Chit-Chat | 2 | 22nd June 2006 05:41 PM |
| Cold Cathode "dual" inverter question | dinofx | Electronic Projects Design/Ideas/Reviews | 3 | 21st February 2006 03:17 PM |
| using a 320W flash with a 150W inverter | denoise | General Electronics Chat | 5 | 19th February 2006 04:44 PM |
| Help on desiging a Discrete inverter to replace 74HC04 | 8899 | General Electronics Chat | 22 | 17th October 2005 04:47 PM |
| inverter or inverter? | glmclell | General Electronics Chat | 1 | 11th August 2004 01:17 AM |
