Old 19th October 2005, 08:40 AM   (permalink)
Default callibration
what does it mean, exactly, when one says he's callibrating the time-base of his oscilloscope with a 50hz sine wave? could it be that the 'length' of the time-base / time axis would be the period of the sine wave?
Everybody can but not everybody will.
aibelectronics is offline
Old 19th October 2005, 09:21 AM   (permalink)
Default Re: callibration
The x-axis of a scope is time per division, the 50Hz mains voltage in the UK (although you DON'T have your location filled in!) is extremely accurate (at least long term), so you can adjust your scopes timebase calibration against the mains signal - assuming you have some reason to want to adjust it?.
Old 19th October 2005, 09:30 AM   (permalink)
Default reply
ah no! no! i'm not using it to measure the mains supply, it's a digital oscilloscope and the chips would fry at 220/110v mains supply, unless of course i get a reasonable voltage divider and series resistor for reducing the current.
the circuit is for measuring 'small signals' of less than 1khz.
Old 19th October 2005, 12:22 PM   (permalink)
Default Re: reply
A x10 probe would normally be sufficent to measure mains voltages, depending on the scope specifications - assuming the scope isn't earthed of course 8) (see another thread!).
Anyway, I wasn't suggesting you wanted to measure mains! - only that the mains voltage would probably be the source of the 50Hz that you could use to calibrate the scope against - it could either be direct, or (more likely) from a low voltage transformer.
But, to be honest, it's not something you need to know about, there's little reason to want to attempt calibration of your scope - particularly as you know little about it.
Old 19th October 2005, 02:39 PM   (permalink)
Default reply
Thanks Nigel, I think I get it. Essentially by callibrating the time base with a 50 hz sine wave, for example, means making the time/x axis be of a dimension to adequately 'capture' the nature of the wave or other waves within its frequency vicinity. We might decide for example to make a 'box' or a unit to be equal to 5msec, a 50hz wave would therefore cover a cycle within 4 'boxes' (4 x 5msec = 20msec).
A problem arises when we measure a 5khz wave, for example, against this callibration as it would make several cycles within a single box. We then would have to alter the callibration to adequately capture it . So yes a time base callibrated against 50hz would be good for measuring mains supply and we wouldn't, if at all, need to change it very often, as we would not expect the frequency to vary very much.
Old 19th October 2005, 08:24 PM   (permalink)
I do that all day long now that I am retired early: "Everyone should have at least 30 minutes a day where in he could fantasize, be a child again and have only himself to worry about."
I do remember to talk and play with my wifey, and feed and walk the dog. :lol:
audioguru is offline
Old 20th October 2005, 05:02 PM   (permalink)
Default reply
Oh in case audioguru's post seems out of place it's only because i've now changed by signature
Old 20th October 2005, 05:45 PM   (permalink)
I'm glad I copied your signature before you changed it.
Old 20th October 2005, 05:59 PM   (permalink)
I was thinking about your new signature, "Events which we think are random, might upon careful study, reveal a pattern in the background acting behind their happening..."
What happened to those cool large photos that appear random at 1st glance, but if you get close and relax your eye's focus, you see a 3D pic?
I got pretty good at looking at them. I haven't seen one recently to try with my new high-tech glasses.
The high-tech coating on my new glasses seems to convert infrared (heat) to visible light. I can see unmentionable things in the dark, on the beach and just about anywhere! :lol: :lol:
Old 21st October 2005, 08:53 AM   (permalink)
Default reply
Ouch!
perhaps i shouldn't have changed it afterall?
