| I'm trying to build a tachometer from the electromagnetic noise emitted from a car's ignition coil... I've had some success in separating the signal from the noise but I'm kind of stumped... After some experimentation with an oscilloscope it seems I get the clearest signal using one loop of wire, half-inch diameter. I'm connecting only one end, since it seems the signal becomes very weak if I ground the second end, and plugging it into the circuit like in the attached figure. I place the coil 5 to 15 cm from the car's spark plugs and connect it to the circuit via shielded cable. The signal in question is made of very high frequency spikes which happen every time a spark plug is fired. On the scope they're so quick I can barely notice. I'm having a hard time because if I try to make the antenna more sensitive (winding more loops into the coil) it attenuates the spikes and they get lost among the noise... If I make it less sensitive the signal will be too weak to work with... I did found another circuit using a similar approach, here: http://www.redcircuits.com/Page23.htm Unfortunately that configuration didn't produce good results for me... What do you think? Is that a reasonable setup or is there some antenna or circuit configuration that could yeld better sensitivity to this signal? | |
| Did you try puting an coil close to the ignition coil to detect the changing magnetic field of the coil being swicthed on and off.
| I wonder if a hall effect sensor would work better?
| well most tachometers that I have seen use the 12v part of the ignition coil to trigger from... with a zener diode and some caps/resistors for input protection and all, you can get a usable signal out of it... or are you specifically going for non-contact sensing?
__________________ EEgeek.net | |
| | (permalink) | ||
Today I ordered an inductive sensor of the type used in ignition timing lights and automotive multimeters for the exact same purpose... we'll see if it helps.. | |||
| you should try wrapping a wire around the wire going from the ignition coil to the distributor and seeing what kind of signal you can get... it will probably be a whole lot better than what you get just by holding an antenna near it.
| Another idea is a microphone to hear the RPM. I think pike did that to measure the RPM on his lawnmower with his oscilloscope. Or maybe it was someone else.
