Old 17th October 2005, 12:08 PM   (permalink)
Default Hey need help with telephone stuff
Can anyone please help me to find the telephone regulation, for a telephone to ring (voltage, frequency etc') in north america\canada.
Thank you very much
Dor
chefach is offline
Old 17th October 2005, 07:00 PM   (permalink)
Telephone line ringing in Canadian cities is with 90V RMS 20Hz riding on the telco's -51V battery. The cadence is two seconds of ringing followed by 4 seconds of silence.
I don't remember how little current is allowed because the feds call it "ringer equivalence number" instead of the actual current to confuse everyone. I think you are allowed a max of 5 old-fashioned mechanical ringers on a phone line.
If your homemade gadget exceeds the max current then the feds will come to chop off your head. :lol:
audioguru is offline
Old 29th October 2005, 11:50 AM   (permalink)
Yeah its pretty similar in the UK too, 90v RMS @ 20hz, max on Hook current not to exceed something like 10 micro Amps.
Megamox
Megamox is offline
Old 29th October 2005, 02:09 PM   (permalink)
Do they also decapitate people who exceed the max allowed current in the UK too? :lol:
Old 29th October 2005, 02:30 PM   (permalink)
No, it's more serious in the UK :lol:
Unless things have changed in recent years?, you're not allowed to connect any unapproved apparatus to the UK phone system - which means you can't connect anything home made (unless you want to pay many thousands to get approval?).
Old 29th October 2005, 06:12 PM   (permalink)
Im not sure how they go about the business of detection. Drawing the same, if not less, on hook current as a standard telephone should be very difficult to detect.
Megamox
Megamox is offline
Old 29th October 2005, 08:45 PM   (permalink)
In the old phones, when on-hook only connected the ringer coil (1kohm) serial with 1uF capacitor to line. This mean about 8-10mA ring-current. In my country not possible connecting over 4 old phones. When problems occurs, in the phone-centrale easy to measure the number of ringer (phone).
Sebi is offline
Old 29th October 2005, 09:04 PM   (permalink)
Maybe the Telco is smart and when they detect too much ringer current then they can send a high-power blast down that line to blow-up the home-made stuff. They do it anyway to get rid of ice on the line.
That's what we did when someone put his own 8 ohm speaker on a 70V PA system. His speaker overloaded the PA amp and was hard to find, so we connected the line to 120VAC for a second to blow-up his extra speaker. The whole building hummed for a second and in one location there was a BANG! Lotsa fun. :lol:
Old 29th October 2005, 10:03 PM   (permalink)
I don't think they actively hunt for illegal devices, but if you are caught the penalties include UNLIMITED fines!.
Old 29th October 2005, 11:34 PM   (permalink)
In my experience, as Nigel said, they don't actively search for problems. Mostly the problems "report themselves." As in the customer with faulty equipment will call the phone company to report a non-working line. When the phone comapany checks the line and finds you are the source of the problem, well, the problem is solved.
When I worked for a cable TV company, on slow days we would root out suspected illegal taps. On the cable system there was a FM signal added that had a warbling tone. While driving around in a service truck on routine maintenance, an ordinary FM reciever was set to the right frequency, and if you heard the tone, you knew either someone was using twin-lead/crappy coax to an extra TV or a faulty cable drop was radiating. Knocking on doors would often cause the signal to "magically" stop as people disconnected the illegal taps. We would say we were trying to fix a problem in the area, and wondered if everything was OK with their cable service. 8)
zevon8 is offline
Old 30th October 2005, 08:50 AM   (permalink)
We used to run two old small cable systems, all valve equipment, and all thrown out once local relay transmitters appeared :lol:
They used line level cables and resistive tap-off boxes, both were all VHF, and only one included UHF channels, down converted to VHF.
One day we got loads of reports that one of them was down, it turned out some guy had connected himself directly to the main line, shorting it out for everyone else down stream.
We disconnected him, reconnected him properly (and got him to sign a contract!) - but he had to pay to have his TV repaired as well, the front end valves needed replacing to make it work. Presumably due to the high signal levels?.
We were so pleased when we ripped it all out :lol: it was such a pain!.
Old 30th October 2005, 10:46 AM   (permalink)
I dont think telecom tests stuff anymore. I've recently found caller display units, supplied by telecom, that fail to comply with their specifications regarding line loading and wetting pulses. Consequently I've built stuff that also doesnt comply, saving a good handful of components and a lot of PIC code. No trouble at all with it, and I've even left the stuff on while telecom engineers looked for a line fault.
spuffock is offline
Old 30th October 2005, 03:09 PM   (permalink)
What's a wet pulse?
Megamox is offline
Old 30th October 2005, 11:03 PM   (permalink)
I think a "wet pulse" is a fairly high voltage, high current pulse sent down a telephone line to burn the oxide off relay contacts. A dry circuit has very little or no current like from a dynamic microphone (coil and magnet) and needs a relay with gold-plated contacts.
