| hi there i have a MW radio for repair but it has no component problem , the real problem is from the home voltage(220v)... the radio has alot of noises at all frequances... does anyone know how i can ignore this noise? i think i need for a kind of filter but dont know more.... thanks for any input | |
| If you have flourescent lights, these generate a lot of noise that is picked up by the antenna. The only solution I know of is to move the antenna away from the lights. If flourescent lights is not the problem, then most likley the power supply filtering is bad or you may need to add a noise filter to the input line.
| thanks for the relpy ino the antenna is not the problem the problem is from the supply... dpo you know if i have to bbuy an filter or amke one myself? what kind of filter i need? | |
| becuase when i go to a place with no mains i have no a such problem... i have this problem even when i use from batterys as supply i have this problem with old an cheap radios and the expensive radios have not this problem.. i am sure this problem is because the cheap radios dont use from filters at the suplly part i am pretty sure that the problem is from the mains transformers.. | |
| | (permalink) | |||
You said there was a problem when using a battery supply, but now you say that an expensive radio is OK, is that in mains or battery? Please get your facts straight! JimB
__________________ Experience is directly proportional to the value of the equipment ruined. | ||||
| Jim, if you read all the posts you can see that there was a post by "Russlk", he said that the problem may be from the florescent lights...i wanted to say the the problem is because of mains, so a radio hase to have a filter for ignoring the noise cause by the mains.. the expensive radios have an filter but the cheap and old radios(AM radios) dont have commonly if you think there was a contradicting about the mains and the batteris supply then i must say the my mean about "i have this problem even when i use from batterys as supply " is that the problem is from the 220V cables at the home and the street and if i use from the batteries in the city the problem will not lose, but at out of the city i have no problem. the only solvation i know is using from the filters but i dont know what kind of filters are ok. hope i could say me maen with my bad english lang | |
| If you have the noise when operating from a battery, then mains filter will not help. Perhaps the noise is coming in the intermediate frequency (IF) in which case shielding the chassis with aluminium foil may help.
One thing that occurs to me, are the "cheap radios" AM only and the "expensive radios" have FM? FM has noise rejection features and operates at VHF, where the noise (usually) cant reach. JimB
| Your mention of "MW" suggests AM broadcast band or somewhat higher frequencies. You might want to clarify the range of frequencies and mode (AM, FM, etc). If it's AM mode then the more expensive radio might have a noise blanker or similar feature where the other does not. A noise blanker doesn't make the noise go away - it mutes the reciever for the duration of the pulse - the duration is hopefully very short and not noticed. Is it possible that one kind of detector might be more sensitive to noise than another - for AM? I don't know the answer - others here might. Describe the noise. It it continuous, with no gaps or does it come and go as you tune up or down the band? I live in a moderately noisy area and almost gave up on problems like this. One day I decided to do some experiments. I had my radio going and shut all the power off - some noise went away - enough that if it were always gone I'd be happy. I turned the power on, one circuit at a time, until the noise returned. There were several sources. The worst was a touch lamp - I got rid of it. I could reduce but not eliminate the noise. My microwave, computer and refrigerator also contributed. The computer was off but still plugged in - had to unplug to get rid of the noise. The touch lamp was the worst and I live with the rest. You might do a similar experiment. Powerful transmitters can overload the front end of a reciever and make it look like there are noises or stations where there are none. Some better (usually more expensive) recievers are more immune that the cheaper units. A filter on the antenna to pass only the frequencies of interest - or to block the overloading frequencies - is the solution. Hope this helps.
__________________ stevez | |
| hi there, i am newbie, and have a lot of question, please help me If you have flourescent lights, these generate a lot of noise that is picked up by the antenna <-- why the fluorescent lights generate noise? If you have the noise when operating from a battery, then mains filter will not help. Perhaps the noise is coming in the intermediate frequency (IF) in which case shielding the chassis with aluminium foil may help <-- what is intermediate frequency? One thing that occurs to me, are the "cheap radios" AM only and the "expensive radios" have FM? FM has noise rejection features and operates at VHF, where the noise (usually) cant reach. <-- what is the range of noise? how is the bandwidht of noise?? what is the application of BPF and BSF?? thank you | |
| The flourescent light is basicly an arc, which is the reason it is noisy. Do a Google search for "superhetrodyne" it will explain IF frequency. BPF: band pass filter, used to pass a desired frequency and reject others. BSF: band stop filter, used to reject an unwanted frequency and pass others.
| okay, thank you russlk and.. the band pass filter, maybe i used a lot of grammar error thank you very much | |
| An allpass filter is used to change the phase of the signal without changing it's amplitude. Filters always change the phase of the signal and sometimes that is objectionable. An allpass filter can correct the phase shift caused by another filter. A bandstop filter is used to remove noise or interference. A notch filter might be used to remove 120 Hz hum, for example. Bandpass filters are used in audio equalizers, and the IF amplifier in a superhet radio is a bandpass filter.
| please tell me what kind of filter that caused the phase shifted, so we need the allpassfilter to correct it what is 120 Hz Hum?? thank you very much zhi yi | |
