| here is the schematic wat type of amplifier is this IC?? | |
| That audio amp has the lowest noise and distortion that I have ever heard. (Seen?) As audiophiles say, its sound is very transparent! :lol: Even if we could see its schematic, what is an amplifier's type? 1) Cheap or expensive? 2) Lousy or excellent? 3) Tooobes (valves) or solid-state? We will just wait for its schematic to be attached then see that it is a Cmos inverter self-biased as a linear amplifier or sumpthin'
| i found its data sheet it is a Qusai AB type amplifier will this circuit work? i'll start working on it from tomorrow can u explain its working a bit? the 2 capacitors in parallel..what is it called? | |
| | (permalink) | |||
It's done because the decoupling effect of the large electrolytics will be less at higher frequencies, so adding a small non-electrolytic capacitor in parallel can improve decoupling at high frequencies. | ||||
| The LM3875 is an excellent audio amp IC. Look at its product folder: http://www.national.com/pf/LM/LM3875.html In the folder is a link to its datasheet that you should have. It has details about heatsinks and stuff. :lol:
| thnx guru | |
| dual power supply how will i check my project at home? i hav a dual power supply in univesity... not at home.... ne shortcuts? or how do i design a +-25 volt power supply? | |
| Why use shortcuts when building an excellent power amplifier? If its supply was a single polarity the the amp would need the problems of a huge output coupling capacitor. Wait a minute! This is a bridged amp. It will work fine without an output coupling cap if you properly bias the inputs so it can use a single +50V supply. It might have a pretty big "bang" when it is turned on or off unless you plan to have its input coupling cap charge and discharge slowly. I started reading all the artilces and comments about these "Gainclone" amps on the web. Some are hillarious.
| The 2nd amp amplifies the distortion of the 1st amp, so maybe the 2nd amp should be inverting and get its input directly from the input. :lol:
| Why is the very bottom resistor 24K?. | |
The original was wrong.
| ok..i am making a dual power supply for it too it'll earn me more marks i found a schematic for it if tht output is less than 25 say...23 or 22..will by power amp work? or should i make a supply with a wider range? say till + - 35? how can this one be improvised? using a higer rating transformer? ne other changes? | |
| check the schematic i attached...is it fine??? | |
