| I have built this circuit 3 times, I havn't found anything wrong with it, but the LED stays on all the time. I was hoping that one of you guys can find something wrong. | |
| Your CDS is doing nothing. Tell me what do you think it is doing in this circuit? Answer.. NOTHING. Q2 Emiter, has constant access to Positive and the Base of Q1 has its negative. Your circuit is always On as long as the base of Q1 is negative, So your CDS should be in series from Base of Q1 to R1. And R1 should not be directly connected to Base of Q1. Make Sense????? | |
| I think it should be like this:
| Yes, Thank you. I had a hunch it was with the CDS and R1 config. I'll build it and see if it works now. Thank you | |
Audioguru shows the right way to do it. The only thing wrong was the value of R1, although the value of R2 (100 ohms) is going to allow about 50 or 60 ma to flow through the LED. A safer current level for most LEDs is about 10 - 20 ma. I would make R2=300 ohms or greater. | ||
I wanted him to smoke his LED and learn about having too much current the hard way. 60mA continuously through an LED would look spectacular (for about 5 seconds)! A 9V battery is mosly wasted when powering a 2V LED. A 9V battery has 6 tiny AAAA cells inside so doesn't have much capacity to waste any. Therefore I would use three alkaline AA cells in series to power the circuit. When they are new, the LED current will be 26mA for a red LED or 13mA for a white or blue one. When the cells' voltage drops to 1V each at the end of their life, a red LED will have about 12mA and a white or blue LED about nuthin'. Three C or D cells could be used for much longer life. R1 should be changed to 27k or 33k when a 4.5V battery is used. :lol:
Your idea of using 3 AAs is a good one. | ||
| Im confused. Why would the ckt not work. If the resistance of the CDS falls to 3k as stated in the diagram wont the base be at a positive potential hence causing the darlington pair to become inactive. If you look at both the above circuits they form voltage divider working on the same principle. We may need to simply change the value from 4.7K to 10K to provide a higher tolerance
__________________ Artificial Neural Networks are dangerous to mankind | |
Look at AudioGuru's drawing. It is easier to understand, and is the same topology. You are correct in saying that they form a voltage divider, but 10k will not solve the problem. 68k will. Of course, if you use 4.5V, you have to change the value of R1, as AudioGuru pointed out. | ||
