| Quick question from a newbie. I recently bought several LEDs in the 8000 mcd and a couple of flashers in 1500 mcd. I have worked out the resistors values I need. What I need to know is if everyone solders the resistor to the anode (long) side of the LED. My next question is regarding the flasher LED. Its flash rate is 2.4Hz under 10V which is is forward voltage and its 30mA. My DC power source will be 4.8 Volts at 1.2 Amps. Should I have a resistor on the LED even though I am running 5V instead of 10V | |
| well, you can solder the resistor on any led it won't make a diffrence. yes you should still put a resistor on the flashers, the power source you are using is 1200ma and you only want 30. i cannot work out the right values though, i just use 1k.
__________________ when you post that reply, im just kidding. | |
| | (permalink) | ||
Anyway you won't loss anything if you open this link as I wrote below this post of mine :wink: | |||
| sorry , i wrote 1.2mA , I haven't paid attention of that | |
| Here are the specs on the flasher LED nominal is 5V max is 10V http://www.superbrightleds.com/specs/bw1520_specs.htm Thanks for the info. I will place a resistor on the flasher. | |
| The LED doesn't have a forward voltage up to 10V, it's the Cmos blinker circuit in it that operates from 3V to 10V like any ordinary Cmos IC. I suspect that it doesn't need a current-limiting resistor since the Cmos circuit in it will limit the current. It will be at its max of 30mA with 10V, its nominal of 20mA at 5V and hardly work at 3V. Somebody said to use a 1k resistor as a current-limiting resistor. Then for 20mA it will need 20V more! 4 Electros, The site that you mentioned is stupid. They have a chaser project that they say lights one LED at a time, but they use a separate current-limiting resistor for each LED when only a single resistor is fine. Put the single resistor in the common voltage feed to the LEDs to reduce their current from about 12mA without a resistor.
| Some flashing LEDs dont need an curent limiting resistor.It just needs to be the right voltage. But you beter put one in in case its not one of those.
| You ware a litle faster then me audio.3 minutes to be exsact(check the times.)
| I would one test for a resistor with an LED with cmos circuit ? Would a 0 Ohm 1/4W Carbon Film Resistor be good. I actually dont understand a 0 ohm resistor. Like I said I am new to all of this. The application is on an R/C aircraft and the LEDs will plug directly into the receiver which puts out 4.96 V according to my DVM. I calculated all my LEDs at 5V for the resistors value. | |
__________________ Everybody can but not everybody will. | ||
| He proboby messd up somting. an 0Ohm resistor wod be a pice od wire.
| | (permalink) | |||
If the LED isn't bright enough then reduce the value of the resistor. Quote:
You don't have an LED, you have a blinker circuit. Its spec's don't say how much current it draws with a 4.8V supply. Maybe it is perfect and limits the current to exactly 20mA with any supply from 3V to 10V. You don't know how much current can be driven by the output of your receiver but you can find out by trying it. Now you say it is for an RC aircraft and you are using more than one flashing LED. The battery will be drained in nearly no time. If I was you then I would make a blinker circuit that blinks the LEDs for very short bright pulses, therefore the battery will last for a long time like in my Ultra-bright LED Chaser projects: http://www.electronics-lab.com/proje...004/index.html http://www.electronics-lab.com/proje...003/index.html
__________________ Uncle $crooge | ||||
