Originally Posted by Scarr
I have a project using a Atmega128 and GSM module and it's going to be battery powered the battery / capacitor combination can handle the 2A pulse but I have a couple of questions.
1) Does a battery powered circuit need any conditioning
2) Is it normal / advisable with a battery powered project to use a buck regulator to maintain the voltage (bearing in mind it could pulse to 2A)
Thx
Alot will depend on how fast the 2A pulse relly is. Probably the most obvious concern is the voltage rail that supplies the pulse. The concerns is that it will droop sufficiently to cause other circuits to malfunction. As for the buck converter, the pulse is treated as a transient load step. i.e. load regulation comes into play.
