| Anybody know where to get side emitting LEDs for cheap? I cannot find anywhere! Everywhere I look at is either rediculously exppensive or is out of them :x I want to try them out with my 1W LED maglite.
| Why side emitting? | |
| Take a look at this picture of the datasheet. On the top is lambertian. Bottom side emitting. Side emitting puts most of it's light to the sides, or in my case, into the reflector of my maglite. Lambertian puts some of it's light into the reflector, but most of it just shoots straight out of the maglite. I want a SPOTLIGHT :lol:
| Won't it be a nightmare to adjust the position of a side-emitting LED to be in the focal point of the reflector? Does the reflector move back and forth in a Maglite when you turn its end? Then it will be fine. I think a focussed LED is better (without needing a reflector), but its extra length probably won't fit into a flashlight.
I never heard of it before. Why not just get a normal LED and turn it on it's side? :wink:
__________________ -=: The best low-priced components to troubleshoot with are the speaker and the LED :=- | ||
| cool so the light pops out the side of the LED , sort of like an incandescent bulb, and gets reflected off the reflecter.. | |
| Hey Zach, Look what the Brits can buy! It's a wide-angle 1W LED mounted on a TO-220 package for easy heatsinking. It even has a built-in reverse-connected rectifier to operate it from AC. http://www.maplin.co.uk/Media/PDFs/Module%2047399.pdf
| WOW thats just so cool.
I wonder if they embed a little reflector in the plastic .. | ||
| 'ow do day do dat? Maybe they are expensive because they use a diamond as a reflector. My ordinary LEDs have some light coming out their rear. Their designers haven't thought about putting a reflector behind the chip. Ordinary tin-foil will work.
| Well, it's actually pretty easy to adjust to the right focal point audio. It's impossible to adjust the focal point on the maglite with an LED, so I just grind down the back of the maglite reflector until it is at the right focal point with my LED :lol: . Then I just take some steel wire and tighten the LED to the reflector. Tried hot glue without thinking teh first time, only to have it melt :shock: Hmmmm, optics, I'm going to look into some optics. By removing the reflector (since I won't need it anymore) I would imagine it would give me loads of room for optics. i'll get back to you guys on that. BTW, I found a really cheap place to buy 1W LEDs: http://www.quickar.com/lux.php BTW, can I in the USA order from maplin without emptying my savings account?
| You didn't forget about Lumileds, did you? Side emitting 1W whites, $5.95, 3W $8.50: http://www.lumileds.com/products/family.cfm?familyId=1
| Hey Oznog, funny, I decided to check them right before coming to this forum. I thought that they would be expensive, but it turns out they're the cheapest I can find, with the best selection :lol: . I looked at them one time before and the LEDs were much more expensive, but I guess that was because they were JUST emerging. I just wish that they had optics :cry:
