| i want to design current source with around 12khz and variable amplitude (1 mA - 15 mA) using ic's not transistors thanx | |
__________________ I'm no electronics god, i just talk too much. | ||
| A current source must be a very high impedance so that any change of load resistance doesn't cause the current to change. You could use a very high voltage feeding its current through a very high resistance, or use the collector of a transistor.
| Actually, if you want to look at it, a transistor is considered an IC. IC = Integrated circuit. a transistor is a chain of 2 diodes with either both cathodes or both anodes connected together. it is the simplest IC, even though the complexity is low.
__________________ -=: The best low-priced components to troubleshoot with are the speaker and the LED :=- | |
| You can't make a transistor with two diodes. A transistor isn't a circuit. An IC is an entire circuit.
| he was only trying to convert mohamed to transistors instead of IC's and u went and spoilt it :twisted: 8) :!: :?: :idea: :arrow:
__________________ I AM the exeption that disproves the rule in many ways but the rules still apply (unfortunately) my site:www.simons-photography.com http://rushdenrotaract.org.uk | |
| frankly i think he is at least a little bit confused else I am realy lost. why is 12 KHz necesary ? what has it got to do with a current source. if precision is not necesary he can just use a transistor with a suitable resistor on the base and measure the current with a tester and ajust until correct then just feed the base via the resistor with the 555 output. or make a precision current source like someone else will have to suggest and power it with the output of the 555 or even gate the current with another transistor.
This is the eighth reply, and we've no way of knowing if any of them has the slightest relevence?. | ||
| PRECISELY :!:
| Maybe he wants to feed the 12kHz current source to the base of a transistor amplifier to avoid the high distortion caused by the transistor's transconductance non-linearity when it is fed by a voltage source.
| well until he tells us what he is about we can only make conjectures
