Old 6th October 2005, 09:12 PM   (permalink)
Default Node Voltage Help
Hello,
I'm supposed to perform node voltage analysis on this circuit, I don't happen to have an image of it now (maybe later) but I shouldn't need one anyway. The circuit has 4 nodes, and between 2 of the nodes there is a voltage source (nothing else). The vs isn't in series with a resistor so I can't source transform it, so I used another method we learned where I make the node nearest the positve side of the vs equal to vs, and the other node equal to zero. Did I do this right? and if so, Should I solve for the other 3 nodes? (all except the one I made vs) Or should I use the 0V as the reference node and solve for the other 3(even though I know 1 is already 4v???)?
Yeah this is pretty long I'll try to get an image up later.
SeanHatch is offline
Old 7th October 2005, 04:45 AM   (permalink)
ooo...the 'super node' problem. I cant really remember how you do it.
So you are changing your ground reference point? I dont remember learning anything about that.
Cant you just make an equation out of it. ( say the - side of the VS is connected to node B and the + is connected to node A)
Then you can just say that VB+VS=VA...(which is also says that VS=Va-VB which sounds right).
That then can be used as 1 of your 4 equations.
Jeff
jrz126 is offline
Old 7th October 2005, 04:56 AM   (permalink)
Hmm, Ill give it a whirl. I've attached a picture now:
