| Hi. i'm new to this forum. i have been searching for a circuit that will start and stop a diesel engine. i've seen these for sale for several hundred dollars each. i would like to have this circuit automaticaly start up a diesel generator from various diferent inputs. i can do the circuts to generate the inputs, but starting this internal combustion engine is not a circuit i have seen before. has anybody seen a circuit for starting these types of engines? any halp would be appreciated. thanks, Mike. | |
On my 15 kva generator it has a NO/NC relay to turn it on and off but you haven't supplied enough detail on the motor. Some diesels have a pull cord to disengage the fuel pump where others use a solienoid. If you can provide a picture of the diesel then we might have a better understanding on where to go but with no information to go on where does one start???? Cheers Bryan
__________________ " The only way to avoid human error is to avoid the use of humans" | ||
| well, the generator is still down in Ft Lauterdale. i need to go pick it up so i cant really say much more about it. i was looking for a circuit that would be similar to this gizmo...... http://www.xantrex.com/web/id/386/docserve.asp it looks like it uses timed relays to activate the starter. they don't give you a circuit diagram so i was looking on the web for a circuit that would do some of the things that this auto start gizmo does. | |
| Are you wanting to start the generator from a remote location? Or do you just want to start it to make sure it's ok? Here in Tn all health care facilities must have an "exercise timer" that starts the generator automatically at least once a week to verify it's operation. Typically all you need to do is parallel the ignition switch with other contacts, one set for crank (momentary), another for run (maintained). A description of what you mean by I would like to have this circuit automaticaly start up a diesel generator from various diferent inputs. Would be a big help..
__________________ gerty | |
| ok, well, automatically start up would mean that i want the generator to start up and run with out me doing anything. various diferent inputs could mean several things. that generator exerciser function you mnetioned would be a good example. annother one could be a signal from an inverter that the bank of batteries is getting low and the generator needs to start up to charge them. i was just looking for a circuit to operate the engines starter motor. it needs to be energized to start the engine, but how does the circuit know that the engine has started and it can stop cranking it over? that's the only part that i can't figure out. if it's a human doing it, he just lets go of the key when the engine starts. how does a circuit know when to let go of the key? i was wanting to see a circuit where some one else has handeled this problem to get some ideas for my own circuit. thanks, Mike. | |
It can be programmed for a certain length. I started with the lowest time, 0.3 seconds and worked my way up.
__________________ Jeff To the optimist, the glass is half full. To the pessimist, the glass is half empty. To the engineer, the glass is twice as big as it needs to be. | ||
Presumably the generator won't produce full output until the engine is actually running?, although it may produce some output while it's turning over - measure the relative outputs, and switch the starter OFF when the output passes a suitable point. | ||
| well, a diesel is not going to start up so predictably every time. it could take a few cranks to get it up so i'm not so sure that a "timed" only circuit would be sufficient. Nigel had a good idea though and i just found this link that has a breif discussion on this subject. it talks about two circuits that will disengage a starter motor when the engine has started. they key off of the alternator though. here is the link for anyone interested. the discussion is on page 20, "ADLO" circuits. http://www.rebelwolf.com/downloads/CrankMots.pdf there isn't very much spisific information on the circuit, but maybe i can figure something out from the information given. thanks for the help and ideas. Mike. | |
I think this is the sort of circuits you are looking for. The circuit consists of several timer relays and voltage relays to detect the successful running of the diesel engine and then apply field excitation to the generator. It is much simplier now to just use a microcontroller for all that.
__________________ L.Chung | ||
| Hi folks, this is one I have thought about alot in the past (more for car engines than anything else...) but what about two possible options. 1. Look at RPM of engine, get a micro to cut starter on sudden increase of RPM (as you would expect, surely the engine will idle much faster than the starter can turn the engine?!?!?) 2. Look at voltage drop across the supply lead to starter. On starting the drop will be much less due to reduced load and hence drop in current flow! Don't forget if the engine has glow plugs there will have to be an inhibit which prevents starting before plugs have adequately heated! Hope I have given some idea's???
__________________ OLLY_K | |
| yea, that's the kind of circuit i'm looking for. do you know where i can find one like that? microcontrooler is an interesting idea. | |
| One system that I've seen uses an oil pressure switch, same as the one that turns on the oil light. You typically don't have full oil pressure until the engine is running. The other systems used a fixed timer for cranking and monitored the generator output to see that it started..
| Old topic I know, but is there a microprocessor or whatever that could detect sudden increase in RPM / voltage etc? Many thanks | |
Boncuk
__________________ Proper Planning Prevents Piss Poor Performance | ||
| The best way to measure engine revs is to connect to an alternator coil before the rectifiers. Some rev counters already connect to that. | |
