Old 28th September 2005, 09:01 PM   (permalink)
Default Low power relay
Hi all,
I want to switch 2A @ 3.4-3.9v with a ATtiny13 MCU what is the best way t do this with the least components, SSR, Relay? Ideally I want a pin from MCU to pin of XXX that is then used to switch the voltage on/off
Thx
Scarr is offline
Old 28th September 2005, 09:22 PM   (permalink)
Default Re: Low power relay
Originally Posted by Scarr
Hi all,
Thx
Look for SSR. you buy those to switch your mentioned conditions.
They typically have a diode on input with a series limiting resistor and only require about 10mA to drive. The resistor can be very small.
Optikon is offline
Old 28th September 2005, 10:24 PM   (permalink)
Default The ones I have found are 3v and my I/O Pin will be 2.5v
I will be running the MCU at between 3.4v and 3.6v and the spec sheet for the ATtiny13 says that at 3v the min output voltage from a I/O pin will be 2.5v (page 119 of the spec sheet) it does not give a typical or max voltage and I can't see a graph that gives a I/O voltage based on VCC.
Having said that, the PDF is a little confusing for a novice like me so it might be in there.
All the SSR I have found require 3v to turn them on.
Thx
Scarr is offline
Old 29th September 2005, 02:12 PM   (permalink)
Default Re: The ones I have found are 3v and my I/O Pin will be 2.5v
Thx
umm look at this guy. Mosfet isolated SSR
http://oeiwcs.omron.com/webapp/comme...prrfnbr=201651
Its small, you can drive the LED with 10mA so 3V I/O is fine. It can switch 2A
Optikon is offline
Old 1st October 2005, 02:30 PM   (permalink)
Default Positive side switching
Thnaks Optikon for that,
looking at the spec it shows switching on the negative side, I want to switch on the live sideis this OK with this device?
Thx
Scarr is offline
Old 2nd October 2005, 01:04 PM   (permalink)
Default Does anyone know?
Does anyone know if I can use the above mosfet relay on the positive supply to the load?
Scarr is offline
Old 2nd October 2005, 01:29 PM   (permalink)
I cannot open the link, but if te input is optoisolated, it work.
Sebi is offline
Old 2nd October 2005, 03:45 PM   (permalink)
Default Found another link to it
Hi sebi,
here is another link I found to it, can you check it please and comment?
http://www.europe.omron.com/Images/en/165_19405.pdf
Thx
Scarr is offline
Old 3rd October 2005, 04:55 PM   (permalink)
Default Re: Found another link to it
Hi sebi,
Thx
This one will work too!
Driving an LED is easy for a digital part.
Optikon is offline
