I am currently interested in getting as large as a capacitor as possible and I would like to know what devices I should be looking in to find high-capacitance and high-voltage capacitors. as of right now, the best capacitors I haver are 2 200V 330uF camera flash capacitors and a 6800 uF capacitor rated at 35 V that I randomly found out of a particularly tempermental Inkjet printer. My goal for all of these capacitors is to hook them up in parallel, charge them with as many 9V batteries as possible, and try to melt a hole through a dime from the massive discharge of the capacitors. if at all possible, I would like to exceed 1 Farad at at least 50 V. anyway, I need to generate as many sparks as possible, and I would need to get my capacitors from a cheap source (i.e. monitors at thrift stores)
__________________ message posted just in case anybody cares Electronics engineer in High-School Training | |
Your going to need a LLLOOOTTT of caps. 60 000 uF to 60V makes big and loud sparks and makes a hole about 0,5 mm in a coin. Meaby if you look at an surplus store. You may also need more than 50V to discharge those caps fast enugh.Or it will vaporise the metal that is cnotacting and break the circuit. There are easyer ways of making holes in coins,
| | #3 | |
My suggestion is to really consider how much work you are going to need to go through to put an unimpressive hole in a dime. | ||
| | #4 | |
Make sure to perform the experiment near a hospital with a good emergency unit!. | ||
| | #5 | |
E=(V^2 * C) / 2 Joule energy (HEAT): E=V * I * t
__________________ Božo My avatar : It`s a truck full of beer (if anyone was wondering) Laško je zakon!! | ||
| | #7 |
The current delivery capability of the caps is important. In this aspect many parallel caps is usually much better than using fewer but bigger caps to get the same capacitance. There are many people who have build dischargers- usually much higher voltage- that will blow up apples and things. In this case they have 2 electrodes, one of which is tied directly to the cap bank and the other through some form of interrupter before being tied to the other end of the bank. But the truly incredible discharger is the Quarter Crusher. It uses a heavy coil and does not touch the quarter directly. The discharge creates such a fast-changing intense magnetic field that it crushes it into a smaller piece. The coil is destroyed in the process. It requires a huge amount of energy storage and some very high end capacitors. Lesser quality caps may only survive a few bursts. It's an expensive and huge rig.
| | #8 |
i have few brand new nichicon caps. each is 3900uF/400V and with large screw terminals. what should i do with them? maybe a toy coil gun...? | |
| | #9 |
Those must be some prety big caps.
| | #10 |
they are about 3" diameter and about 5" long and have nice strap as a mounting bracket. they ware intended for VFDs. guy in local repair shop didn't know what to do with them as his shop was overstocking them. i offered to find good home for couple of them before they end up in a garbage. they look like this (picture doesn't show strap): http://www.alltronics.com/images/21P001.jpg I didn't have Laško but he accepted Heineken. | |
| | #11 |
| http://uk.farnell.com/jsp/endecaSear...=4704769&N=401 63V (you will need soem voltage de-rating) 150mF so for 1F you need 7 in parallel | |
| | #12 | |
Every beer is better than no beer. :wink:
| | #13 |
ok... how about if i just wanted to simply shock a hole through a dime, with or without capacitors? I'm also working on electrolysis of water... how many 9V batteries hooked in series do you think it would take for me to do some major electrolysis, to the point where I can light a flame over the water and burn hydrogen? Im at 16 batteries, and still adding more...
| | #14 |
Hidrogen dose not burn it explodes violenty. You might try an thing caled termite.Its an mixture of iron oxide (Rust in idiont languge) and aluminium powder.Wen ignited it develops about 2500 C° wich is enugh to melt a hole in a peny. Its so hot it makes ice explode. To get best results you have to catch the right ratio betwen rust and aluminium.
| | #15 | |
They've been using Thermite on the UK TV show Brainiacs, very impress stuff!. Remembering back to my school days, a mixture of aluminum powder and powdered iodine works very well also! - they both need to be ground very finely, and kept COMPLETELY dry - add a drop of water and it starts the reaction, producing huge amounts of heat (that will melt various metals) and massive clouds of thick purple smoke :lol: | ||
| capacitors, find, giant |
