Old 26th September 2005, 12:54 AM   #1
Default Transformer Alternatives?
Hello all techies here!
Just a general quick question:
Is there an alternative to a transformer?
e.g. is there some modern day component that replaces transformers?
If so any idea of the efficiency of each?
AC->DC 230V 2A type transformer (apparently DC transformers exist)
ops: I am dumb and have great ignorance of electronics.
I praise all you people!! :P
jamesdedogs is offline
Old 26th September 2005, 01:22 AM   #2
Depends on the application. For my amplifier circuits, I use capacitor coupling (RC coupling) instead of inductive coupling (transformer).
What are you doing that requires a transformer?
-=: The best low-priced components to troubleshoot with are the speaker and the LED :=-
mstechca is offline
Old 26th September 2005, 06:52 AM   #3
We still use transformers in modern days. There an prety eficent way of converting volatges.
Also coils are somtines used in switchmode power suplys.They use the coils inductance to change the voltage.
Il give you shocking experience.
Someone Electro is offline
Old 26th September 2005, 03:43 PM   #4
There are resistive and capacitive transformerless power supplies for low power applications. They use only a few components and are pretty easy to design and build..
The best reference I've seen is Microchips Application Note 954.
It's available on their website.
lavenatti is offline
Old 26th September 2005, 04:11 PM   #5
thanks all. =)
I just heard from a friend that transformers can now be replaced with tiny microchip type solisoid or something that is more efficent than the old wound windings.
the type he was talking about was like for a laptop or standard issue ones like computer modem ones.
guess transformers are, and always will be king =]
thank you for your time.
Old 26th September 2005, 06:55 PM   #6
Whilst we are on the subject of Transformers, I have a question.
I am building a UV exposure unit. I have designed the circuits, and have all of the fittings and tubes, but I am stuck on the case. I was thinking about making the 4 sides out of out of 15mm thick pine wood, and the bottom & lid from ply wood. Then I would use PVC & perspex for the control panel/display and exposure surface. However, I will be using a 240V - 14V PCB mount transformer. Should I have a seperate box inside the unit, to hold the transformer? Safety - wise, what would you guys do?
roboticmisinfo is offline
Old 27th September 2005, 10:14 PM   #7
Any info would be appreciated - thanks!
Regards
Mike
Old 28th September 2005, 12:05 AM   #8
think you should doa repost.
Old 28th September 2005, 02:18 AM   #9
Default Re: Transformer Alternatives?
There is no such thing as a DC transformer. A transformer HAS to input AC and output AC, otherwise it will not work.
The DC transformer you're thinking about is the kind that you plug into the wall and it outputs DC. The reason it outputs DC is that after the regular AC transformer there are four diodes arranged in a bridge rectifier that turns the AC into a choppy DC waveform, and a filter capacitor that smooths the waveformr. I think I got the part count right?
zachtheterrible is offline
Old 28th September 2005, 12:04 PM   #10
http://www.electro-tech-online.com/v...er+alternative
discusses the opposing view : /
Old 28th September 2005, 12:24 PM   #11
That thread goes round and round in circles trying to define AC/DC/Pulsed DC etc etc.
The bottom line is that to get a voltage out of the secondary of a transformer, there has to be a varying current in the primary.
JimB is offline
Old 28th September 2005, 09:11 PM   #12
Solved!
8)
alternatives, transformer
